Re: Cockpit Instrumentation
looks exellent..... might let you do it to mine if you're a good boy....
Could'nt agree with u more Hugh, only with my failing eyesight due to old age I did mine as
white face and red needles. If u look closely u can c my ACT gauge fitted where the diggi clock
used to be. The buttons are now dummy just to fill the holes that would have been left had I just
taken the clock out.
Thanks for your coments mike.
It depends on what you're going for, your's is a lot more "I'm somthing special, come play with me" with the white dials, steering wheel, gearknob and pedals. I currently am doing things a bit more low key.
I love the way you've done the ACT, that looks superb.
Both look very neet and tidy chaps.
Sapphy thats the first time ive heard of someone actually trying to get a 'black plastic' style finish.
As Magrah said, both look top
Pucka indeed
TS Supporter
I do prefer black dials, but I do have a couple of white one's, boost and water injection pressure (which doesn't illuminate). I was thinking of blocking up the central air vents, but then I decided i'd rather have some kind of ventilation form the centre:
The air - fuel ratio meter is there only because the previous owner had a gr8 big mobile phone holder, which was screwed into the dash (!!!!!), so I "reworked" the holder to accomodate the AFR meter.
TS Supporter
Sapphy , I've got a Webcon Alpha T026 Air - Fuel ratio kit (£145 +VAT + Delivery), which has all the parts required. Basically, you drill a hole in the exhaust as close as possible to the exit of the turbo, and have a threaded boss welded over it, which is where the lambda sensor screws in. More info here:
http://www.webcon.co.uk/alpha/index.htm
Thanks mate. I'm glad you put this to the top as well, I had forgotton what it looks like!!
Dont look like that now them chickens have really made a mess
[Sapphy sobs quietly in the corner of the room]
