eventful times at mine ...
im not a regular post starter.still a newbie but heres an update of the world of cars at my house.
Bloody radiator on the bmw decided to look like a smiley face and start leaking ,so had to get a replacement one in there.
still got to take the old one up with gsf as its only just out of its 2 year warranty and it looks fubar.
Had to blast it down the bypasses to make sure its working ok :wink: :wink:
Still pulls like a train and sounds sweet just as it passes 170k miles. 8)
And in other news been doing a engine swap on the kit car, dropped on a 2.1 with kent cam and gasflowed head cheap.
so new water pump and stat. swap my low profile big wing sump over,alloy radiator and vernier pulley and loads of new studs and various other bits
been out on its maiden voyage this eve, plenty of oil pressure revs up a treat ,just needs the carbs setting up now.
Re: eventful times at mine ...
Looks like a nice set up
Which bypass can you be seen testing on ?
I live in Barnsley . so its either the Hemsworth ones or the cortonwood ones. tests both power and brakes .
