Just put Cylinder Head on - misfiring
righto ho.. can anyone help?
i fitted the cylinder head last night to my S2. Now it fired up fine.. but is running on 3 cylinders. It sounds like a tractor and i found out it is pot 2 beacasue i took each ht lead of in sequence and nowt happened on lead 2.
is this a timing issue? as i have checked the plugs and leads and all are fine ???
i also did a compression test and all pots were nigh dead on 9 bar ?
has anyone any ideas as i played with the dizzy and nowt happened
ta peeps
Dave
Re: Just put Cylinder Head on - misfiring
cheers matey. seeing as you were the ONLY one kind enough to reply
it was leaking injectors pal, all sorted now
Dave
No probs man, glad to hear you've sorted it out.
