knock on 4x4 cossie
i have a knock on drivers side when turning into left handers and then when warm and stright line it knocks again i think its the shaft
i have changed so far all the bushes the tca
2 front konis any other ideas guys?????
Re: knock on 4x4 cossie
Sounds like your offside shaft to me, if you've checked everthing else
TS Supporter
Have you checked the wheel bearings? Probably is the driveshaft, i had the same thing on the passenger side, the CV joint destroyed itself
I was going to say CV joint. When worn it allows the driveshaft to clonk about a bit. It happened on my mates 2wd cos (from the rear though!)
Nice car Sid
thanks for the replys peeps have just ordered a new shaft have been told poss wear due to kb engine mounts
cheers sharon
Let us know how you get on Sid
well new shaft in still it knocks
going to try new enginge mounts and suspension bushes then after that a nice new ish scooby and the cossie can go sit in a lock uo till it learns to behave properly thats what happened to me when i was in trouble
ta Sid
this is exactly the same as my dads cossie 4x4 sapph
it knocks....very badly every left hand bend on the right and its there when going in a straight line
it was the bottom ball joint on the drivers front that was badly worn....even though it was only 18 month old and the wheel bearing....had started to colapse
the ball joint didnt feel worn until a bar was used to see if there was any play...the tension of the antiroll bar was making it seem like there was no play there
but if you have changed the track control arm then i'd go for a wheel bearing
hope this helps
cheers daz but have changed the bearing
i have been told it could be the engine mounts so thats next then i think ill just give up
Sid
odd.....sorry was of no use......your knock does sound strange why you cant cure it
just found out that the knock hasnt gone from my dads 4x4 either....its not as bad now the ball joint and the wheel bearing has been changed.
however i did notice a small amount of play in the front diff (as in up and down bearing play)....when you rocked the shaft back and forth it knocked as well.....we are now looking at having the diff repaired........hope this helps
sound's like driveshaft mate,had same prob! changed driveshaft and sortd it.
daz cheers lets hope not but let me know mate
bradford have changed driveshaft
still no joy
ta
Sid
will do sid but where not pressing to get it done just yet so there might be a delay before we get it done
Sorry I have to agree with wes the first thing I would look at is the unloaded wheel bearing !
TS Supporter
This may sound silly, but are the wheels fouling the calipers? i noticed in your sig the car has 2 different set of wheels in each pic, has the knocking started since you fitted a new set of wheels? Other than that i still recon wheel bearings
well have even changed the top suspension bushes as well but its strange still there but going up a very small bump ie drive kerb it knocked
so now its going into a main dealer on tuesday for them to have alook
ta
Sid
TS Supporter
Re:What was it then?
howere Mark, what was it?
cheers............Ken
