RST fuel
RST S2 modified KE Jetronic fueling:
Does any one have the details of how to modifie the system for more fuel?
Lee
Re: RST fuel
I can do the mod Lee call me :0
Re: RST fuel
Teach me Clint
Lee
Re: RST fuel
Is the mod just turning up the pressure ?
Lee
Re: RST fuel
Lee I can explain in full but I am serious when I say you will need tounderstand the bosch KE system before I would even start, Raising the system pressure would give you enough fueling (probably) for most tuned engine requirements, but as I see it thats what most of the fuel mods do ! Thats why I took a different approach, rather than raise the fuel pressure (therfore the co) everywhere I chose to be clever and target the top end
It really is more technical then people think and you must have access to proper test equipment to firstly create a baseline and then tune to the cars exact requirements.
Remember quite a few people can give you enough fuel for top end by richening the mixture everywhere, but only the select few can get the car fueling correctly through the rev range
HTH
