TS Supporter
Re: My \"360\" conversion.
Hi Wes,
Perhaps not the most ideal position but the water aint that warm actually, the heatshield protects it and i will put some heat reflecting material on the outside of the tank. Water was below 40c when it was setup and it was above 30c outside.
Pectel monitor was reading 40c for peak ACT and the car had been on idle for 2min when i took that reading.
I shall have a look and see if i can put it somewhere else though, but it aint much space left. Perhaps i should put some reflecting wrap on the hoses that goes to the tank, ive noticed them getting abit warm?
Sorry, i havent got verniers so i can tell, you are right about the cover being a GGR item though.
/Andreas
TS Supporter
Ah i just rembered the heatshield goes quite a way down there, maybe it isn't a problem having it there then, some thermo sleeve for the pipe work is a very good idea, don't want them splitting from heat
Stick a 2litre tank in the boot
Looking good Andreas
nice one m8 wes try dazjayes carbon for a timing belt cover he is doing them in prepreg carbon fiber the same stuff a F1 and about the same price www.DAZJAYESCARBON.co.uk
TS Supporter
Cheers for the link Kaibo £40 cheaper than the GGR one!
Andreas the engine bay looks in good nick well done!
