How do you adjust a spark plug ?
My brothers cossie is misfiring, as the plugs are at 0.75mm
it should be at 0.65 mm or summat ? (3dr cossie, 330 conversion)
Plugs are AGPR 701.
I have measuring plates, but how do you adjust the plug ? Do you just knock it against the wall ???
Re: How do you adjust a spark plug ?
i prefer the kerb or a nice big pavement slab, just a slight downward tap gives you that more precise adjustment and control
Gentle taps against a solid item. I use a vice, something that is solid but non-abrasive
thanks,
proved not too easy to get it 100% right,
we'll see what the car does
0.25 SHOULD BE THE GAP USE A FELLA GUAGE OF THIS SIZE BETWEEN THE ELECTROD AND GE IT A GOOD TAP
