N/A Yb breather setup
Afternoon everyone,
I wonder if you can help im running an N/A YB on throttle bodies and was wondering what the best breather setup to use. I have an elbow out the block current which i was going to run to a catch tank, will this be sufficient? I don't really want to drill and tap the rocker cover unless i have to!
Re: N/A Yb breather setup
Take off on the other side of the block aswell. I think it's the turbo oil return?
That will be sufficient breathing
I also use the turbo oil return on the left side of the block as the oil return from the bottom of the breather tank. Top of the tank has a pipercross filter and breather in. Never have to drain the catch tank!
