Webber 3 Bar MAP Sensors
If your having trouble with finding a Stage 3 conversion then dont worry I have the answer here
I am using a new 3 bar MAP sensor which is far more accurate than the Original Webber item it does use a different socket and mountings but will come with a new plug (and bracket at extra cost but you can redrill the original).
Maps have been adjusted to suit and is being tested on Thursday to check the solution
Also I have a Bosch 5 bar Map sensor comming from IMA on Tuesday and I will be using these on and car running 350HP +
I have already adapted the software so just need to test this solution too.
Pricings will be a little dearer at about £450 for a stage 3 kit (injectors, MAP, Actuator, Chip).
Re: Webber 3 Bar MAP Sensors
nice one,
has mark got the inlet now?
Clint,which parts would be needed to convert a 4x4 cos to 330/340 bhp.What kind of boost would it need.It has a stage1 chip,race actuator,s/s ex,d/v.If i were to do the coversion myself how do you know were to set the actuator.Is stage 2 a big difference from stg1.Cheers
