Results 1 to 4 of 4
Thread: 4age on t50
    May 2014
    Londinium
    4age on t50
    Hi have a 4age 16v on a toyota t50 gearbox.
    The starter that came in the box does line up on the gearbox but the nose of the starter fouls the dome of the recess... So it is 20mm proud... Am I missing something or is the starter incorrect for the t50 ? (It probably came off a corolla or mr2)
    Spanner Monkey qcadta's Avatar
    Jul 2007
    Invercargill, New Zealand
    258
    Re: 4age on t50
    it maybe a 1g series starter, theyre a high torque starter so all you need is a spacer kit.
    Click image for larger version Name:	304127128.jpg Views:	97 Size:	4.8 KB ID:	70530
    May 2014
    Londinium
    Re: 4age on t50
    Ahaaaa ! Looks like I will be busy in rhe workshop. How thick is the spacer ?
    May 2014
    Londinium
    Re: 4age on t50
    now have correct starter:
    AE86 starters fit on toyota t50 housing and use serial/part numbers : 28100-15110 and 28100-15130
    The one i had was an mr2 starter from a later series with bolt holes 5mm closer together.
    i still need the 9mm spacer …..
