Any Subaru Experts here ?
Hi
Is there any subaru experts here or can somebody point me in the right direction ?
I've got a subaru legacy turbo (1991 j plate). Its a uk car.
Its just decided to bust its gearbox (5th has gone , rest ok)
Can somebody tell me if an impreza gearbox fits and/or where to get one impretza or legacy, whatever one will go on.
Craig
Re: Any Subaru Experts here ?
Don't know if they fit, but if they do you will have a problem getting them off of the engine.
I did an Impreza one and it moves off box 10mm and then jams solid.
If you are doing it yourself you need to undo the 10mm allen key on the NS of the bell housing and remove the release bearing shaft then it comes off piss easy. If you dont, you have to remove the clutch to free off the box.
Its not a bad job just looks awfull from under the bonnet.
Craig
Hi mate,
I have a number for probably the UK's biggest Scoob breaker will dig it out for you now.
A Impreza box will fit but only if it is from a Phase 1 engined car(up to approx 98MY)but you may also need the rear diff as well depending on what the box comes from.
What has happened to the original box?I have rebuilt quite a few and most can be sorted easily.
Anyway heres that number for you Grade A 01663 744114 and speak to Andy.
HTH
J
Well thats good news .If you need any bits for the box I can have a rummage around for you and see if I can find some bits.
Good luck getting it sorted
J
What do you want to know??
Im building a 600+ bhp impreza at the moment and can be found on www.scoobynet.co.uk
Impreza gearbox will fit.. however..
92 - 96 impreza's use four bolts on the bellhousing
97 on used 8 iirc.. will still bolt up though...
Legacy has a different final drive.. so would possibly need the rear diff..
UK Impreza's use 1.1:1 drop at front so use a 3.54 rear diff..
Wrx's / stis can use 3.9 rear and 4.44
Best bet is stick with legacy bits..
Who's rebuilding the box??
Howard at www.hdcsubaru.com has loads of boxes..
if you rebuild replace the syncro's on 1st and 2nd..
If you want an uprated gearset speak to mark@lateralperformance.co.uk.. garanteed to 450lbft..
How slow is your legacy?? Fancy a remap..
www.scoobyecu.co.uk
David
