Just replaced the hinge pins on my MK2 with NOS pins but both bottom hinges of both doors have some movement, is this normal or any ideas what might be causing it.
The hole that the pins go through will be worn. I believe this can be drilled out and larger pins can be used. It's a common mod. My hinges are the same. Crap
I'm going to pull your head off because i don't like your head!
looks good
