Results 1 to 13 of 13
Thread: L8 ECU / dwell regulation
    Jan 2014
    Antwerp Belgium
    Hello
    Anybody knows how the L8 ECU regulates the dwell ?
    It's in the eprom map or other part of the ecu.
    I assume the ignition amplifier is a "dumb" module? Only transisitor.
    I mesured the dwell and found thid results 1000rpm/17msec, 1200/11, 1500/3, 1800/3, 2000/3, 2500/3, 3000/2.5, 4000/2.5, 5000/2.2.
    Must tell that my oscillocoop is a bit old ,so values may be not 100% but very close.
    Is someone has other results please react.
    Thx
    Patrick
    Clint's Avatar
    Jul 2001
    941,374
    Re: L8 ECU / dwell regulation
    Its in the MAP - Post your Bin and Ill find it for you.
    Jan 2014
    Antwerp Belgium
    Here it is :-)
    Attached Files Attached Files
    Jan 2014
    Antwerp Belgium
    Did some more research on the ignition.
    Click image for larger version Name:	ignition.jpg Views:	177 Size:	138.9 KB ID:	70924
    In the picture the top line is the signal to the marelli module ( pin 24 and 25 from ecu )
    On the bottom lin you see the current trough the coil.
    As you can see it is the module who is calculating the dwell time (+- 4msec) and the ecu gives the exact spark time.
    Even at low revs the dwell time stay's +- 4 msec.
    I think the marelli module is a "smart" module , not only transistors.
    Jan 2014
    Antwerp Belgium
    Hi Jonathan
    Hi
    Did first test today ( and it worked !) of the PIC controlled ignition driver.
    It calculates the dwell I program for the whole rev range.
    Works on the output signal from the marelli ECU.
    Just add the Bosch BIP373 coil driver and a high current coil ( as I go from 6.5 amps to +- 11 amps ! primary current ) and I have almost the double spark energy.
    Click image for larger version Name:	20140810_1515022.jpg Views:	168 Size:	100.3 KB ID:	71089
    Grts
    Patrick
    Clint's Avatar
    Jul 2001
    941,374
    Sorry your right the ignition dwell is controlled by the BKL3 module.
    I was thinking about injector timing. DOH!
    Would be good to modify the output so we can use standard Bosch modules like the 200 twin amp
    Jan 2014
    Antwerp Belgium
    Hi Clint
    I will do some more test first with a crane coil.
    Then i will post the schematics , the assembler file and the circuit board i made for this.
    I think you can put any "DUMB" power amplifier after this controller , starting from the marelli (or other brand suited) ECU signal + program the dwell time you like ( in 0.256 ms increments ).
    NOT the firing point itself !!
    This remains controlled by the ECU.
    The signal has to be an 0-5V signal and firing at the negative flank as seen on the picture above.
    Patrick
    Jan 2014
    Antwerp Belgium
    Hi
    Build the circuit board today and tested it.
    Temperature was fine after one hour at 4000 rpm.
    BIP373 at +- 60°C , coil at +- 80°C.
    Click image for larger version Name:	Foto-0042.jpg Views:	151 Size:	143.9 KB ID:	71437
    On the pictures you see the circuit , the crane coil and the scope image at 4000 rpm.
    The dwell was programed at 4.2 msec ( and is produced correctly as you can see at the image ) and the max current to the coil is +- 11A.
    More dwell puts the coil in saturation and only heats up the coil.
    Bottom signal is output from the PICprocessor.
    This dwell remains the same from 600 rpm to 5800 rpm , then the 4.2 dwell time begins to decline as the spark is at 1 msec there is not enough cycle time . ( for a 4 cylinder engine with one coil )
    But still more than enough spark energy.
    With a dwell at 4 msec the limit would be at 6000rpm.
    The spark energy at 4.2msec , this coil and 11 amp is 282 mJoule !!! which is very strong.
    Next test in the car .
    Click image for larger version Name:	Foto-0041.jpg Views:	153 Size:	133.0 KB ID:	71435Click image for larger version Name:	Foto-0043.jpg Views:	154 Size:	112.0 KB ID:	71436
    Grts
    Patrick
  9. The Following User Says Thank You to cauf61 For This Useful Post:
  10. #9
    Jan 2014
    Antwerp Belgium
    Hi
    Did the first miles today with my dwell control box ( set at 3.25 msec ) and the LX91.
    All ok , coil stays very cool (35°C ° )
    I will take some pictures from installation tomorrow.
    Grts
    Patrick
  11. #10
    Aug 2016
    Mol, Belgium
    9
    Nice work Patrick,
    Jonny Belgium, Mol
    rutsj@telenet.be
  12. #11
    Jan 2009
    italy
    hi my name is manuel and i'm italian. I wanted to know if you can share with me the scheme to adjust dweel time because I would like to use honda cbr 1000 coils directly on the head of my escort thanks
  13. #12
    3,243
    Quote Originally Posted by foxy44 View Post
    The OP hasn't been on here for 3 years so unlikely to answer your question !
  14. #13
    May 2004
    Norn Iron
    1,143
    And running and firing coils for COP is vastly different to a stronger single coil.
