Page 1 of 2 1 2 LastLast
Results 1 to 40 of 46
Thread: Mk2 Escort Pinto Turbo
    Jul 2014
    aberdeen
    35
    Hey all, new on here so thought id share a few pics of my mk2
    Jul 2014
    aberdeen
    35
    Re: Mk2 Escort Pinto Turbo
    Jul 2014
    aberdeen
    35
    [/quote]
    Jul 2014
    aberdeen
    35
    Sorry first pics were tiny.
    Engine
    2.0 cosworth crank and rods
    Male pistons
    Rotomaster AR/60 turbo
    Front mount intercooler
    Lotus esprit turbo twin 45 DHLA dellortos
    H@H ignition turbo pressure retard dizzy
    Standard Cam
    2.5" system
    MT75 gearbox
    twin plate ceramic AP clutch
    Competition lightened flywheel
    English rear axel
    Lanyard rod
    Anti tramp bars
    coilover front sus
    Spax rear shocks
    Adjustable tca
    Wildwood 4 pot brakes
    Shell - originally a police car haha
    Its been a long ground up restoration but well happy with how its turned out :-)
    Jul 2010
    South Wales
    4,689
    221
    Very smart car and nicely put together!
    Moderator+ Turbosport Moderator Longman's Avatar
    May 2007
    Leicestershire
    36
    863
    Me like.
    Not sure if you've driven a Cosiie before. But if so what's a Pinto turbo like to drive in comparison to say a standard/stg 1 YB?
    Jun 2013
    Nottingham
    222
    11
    Very nice mate
    Jul 2014
    aberdeen
    35
    Quote Originally Posted by Longman View Post
    Me like.
    haha yeah my little brother has a t25 escort cossie running around 280bhp, They both give a totally different feeling of fast as the cossie is so planted when driven hard. The mk2 is a totally different experience, it has alot of turbo lag and gives you a real kick in the dry and lets just say it keeps you very alert in the wet!! Not had a chance to run them together yet but will keep you posted...
    Still fine tuning the pinto turbo tho, as only just fitted the turbo retard dizzy so need another dyno session now. It feels alot better than the static dizzy i was using before but I have also uncreased the boost since the last dyno run so hoping for much improved results.
    What ignition systems have people here used in the past for this type of setup?
    Tyre Kicker wurley07's Avatar
    Nov 2006
    folkestone
    58
    That looks gorgeous bud
    Quality pics
    May 2006
    322
    11
    very nice car, quality build, great pictures too and superb location ! enjoy the car
    Jul 2014
    aberdeen
    35
    http://www.scottisholdskoolescorts.c...hp?f=8&t=16811
    Heres a link to the build if anyone is interested?
    Glad folk are seeming to like it and yes im making fully use of enjoying it... its no trailer queen :-)
    May 2004
    Norn Iron
    1,142
    If you're on a budget, the likes of Megajolt or some sort of electronic control over timing would be a worthwhile addition.
    You should be able to fit a system and still retain that old classic look. A lot handier than messing with dizzy advance weights etc, and should make it a little more lively everywhere.
    MJ might require a coilpack, but there are defo systems out there that will let you retain a single coil and dizzy if you want to.
    Superb build though !
    Jul 2014
    aberdeen
    35
    Cheers all. Always good to hear feedback.
    As for going to a megajolt or similar which i am thinking of doing.. as it will give much better results nd control over the ignition. I was wondering do these ignition systems account for a map sensor to control ignition retard when gaining boost pressure?
    May 2004
    Norn Iron
    1,142
    MJ uses MAP vs RPM as the main load axis. It requires a 36-1 trigger wheel mounted to the crank and a suitable sensor. It would also require fitment of a MAP sensor. Both fairly easy to do.
    So yes timing is always taken car of with regards to boost ( and vacuum )
    Only thing with MJ, you must use an EDIS module/coilpack as far as I'm aware
    Some of the other systems would be more flexible and allow a variety of ignition systems.
    Another option to consider, is choose/buy a full fuel/sparks ecu but only use sparks for now. It just gives you more options for the future if you decided to go full EFI, as half the install is already done
    Plus you can still use the ecu for logging things etc
    Jul 2014
    aberdeen
    35
    Sounds good. When i first got the engine running i was using a standard locked out dizzy which worked fine but you could feel the flat spots when the ignition timing was out. Car made 170bhp using that dizzy nd running 8spi boost. The car is now much better with the dizzy upgrade nd running 12-14psi. Not had it back on the rollers yet but just from trial setup on the roads its much quicker nd smoother. From adjusting the dizzy i can get it to have really impressive top end on full boost but then runs a tad rough lower down so thinking a good timing setup will smooth things out and get the most from the setup. Really keen to stick with the carbs as its very unique nd quite oldskool. Also makes a very unique sound :-)
    May 2004
    Norn Iron
    1,142
    I agree the carbs are pretty cool.
    An ecu that had logging ability would be handy. You could log basics like MAP, rpm, temperatures as well as AFR's. Whilst they wouldnt have any direct control over fueling, it can be very helpful with tuning and general running.
    Another cheap competitor to MJ is Nodiz. Maybe worth looking at.
    http://www.nodiz.co.uk/nodizpro-features.html
    Cant comment on how well either work though as never used them specifically.
    Pit Crew Craigorypeck's Avatar
    Nov 2009
    Edmonton Canada
    949
    96
    Like that a lot! I would second the MJ route. Very easy and the results are in a different league.
    I wanted a set of those DHLA45M carbs for my engine but ended up with cheaper bike carbs instead.
    Very very tidy mate!
    Jul 2014
    caerphilly s,wales
    198
    27
    lovely mk2 that .awesome location to take pics.
    nice one
  19. #19
    Jul 2014
    Wolverhampton
    32
    Stunnning mate
  20. #20
    Jul 2014
    Wolverhampton
    32
    What bhp is it?
  21. #21
    Nov 2009
    essex
    6,623
    338
    very cool mate.
  22. #22
    Jul 2014
    aberdeen
    35
    Quote Originally Posted by Jonezy View Post
    What bhp is it?
    Last time on the rollers it was only running 8psi boost and was missing a bit due to the actuator sticking and had a standard locked advance dizzy on it and it made 170bhp
    got the actuator sorted now and the boost upped to 12-14psi now and have cured the missing with a turbo pressure retard dizzy and its a completely different car from the last dyno session.. so will keep you guys posted on what the results are after the next dyno run.
    What would people expect from this type of setup?
    Cheers all for the comments
  23. #23
    Nov 2009
    essex
    6,623
    338
    there's a fella with a mk1 capri running twin 45's from a esprit on a t3 making about 230bhp on about 12 psi.
  24. #24
    Jul 2014
    aberdeen
    35
    Sounds good as that the region i was hoping for. Time will tell. Do you know if that capri was using a dizzy or ECU for ignition?
    I have also been thinking about electronic boost control. Are these easy systems to use and fit? If so is there any particular reconmendations?
    Nov 2009
    essex
    6,623
    338
    when I boosted a carb pinto I just used the standard vacuum advance dizzy but plumb the vacuum line into the servo line, this way it was pulling max vacuum advance at idle, then time the dizzy in as normall. the dizzy works perfectly whilst driving using the centrifugal weights to advance the timing but then as you come on to boost it's no longer pulling on the vacuum advance so actually retards it by about 4 degrees. it was extremely drivable and worked flawlessly even up to odd occasion when I ran up to 18psi.
  26. #26
    Jul 2014
    aberdeen
    35
    Cool, I got a dizzy made by H&H ignitions and they have reversed the vacume advance to retard the timing at 5psi boost. the weights were then done to match the specs for the lotus esprit dizzy and it seems to be working grand. Just wondered if going down and ECU route would unlock a tad more from the engine.
    Jul 2014
    aberdeen
    35
    Here are some more car / engine pics... excuse the old throttle linkage and standard dizzy in these.
  28. #28
    Nov 2009
    essex
    6,623
    338
    Quote Originally Posted by ksuds View Post
    an ecu will always be better and easier to tune but that's not to say a dizzy can't work just aswell if set up right.
  29. #29
    Sep 2008
    south wales
    105
    27
    Thats very nice, just how I'd like an Escort arched and nice interior
  30. #30
    Mechanic cuttsy224's Avatar
    Sheffield
    29
    539
    67
    What arches are they please? Look tons better than the usual ones
  31. #31
    Jul 2014
    aberdeen
    35
    Quote Originally Posted by cuttsy224 View Post
    Its a set of forrest arches in fibreglass with internal mounting lips so they can be smothed off external with no visiable rivets etc. If you look at the link to scottisholdskoolescorts above I think there is a few pics of me putting them on. There also seem to be two variations of forrest arches and the main difference is in the front arches. Some sets stay wide on the return back edge of the fron wheel or like my set they taper back in to the body line and the front edge tapers to meet the mex front splitter.
    They do however take quite a bit more work to get them looking right than using the alloy arches but think the end result is much cleaner
  32. #32
    Jun 2008
    Dunfermline, Fife
    459
    61
    wow, lovely motor, love it !!!!!!!
  33. #33
    Jul 2014
    aberdeen
    35
    Cheers glad you like it.
  34. #34
    Jul 2014
    aberdeen
    35
    BTW did anyone see the car in Retro ford last april?
  35. #35
    Jun 2003
    Teesside
    2,406
    Have you got a single piece prop or a 2 piece? I'm just about to fit the MT75 box in mine but need to sort a prop out. Been told that it is possible to run a single piece prop with a sliding section in.
  36. #36
    Jan 2015
    Wales
    Nice mate real nice!
  37. #37
    Jul 2014
    aberdeen
    35
    Here is a sneeky wee hint for the prop.
    Get a transit 2 piece prop, so you have the rear sliding section. then break the centre uj and the front one from the fixed section then move the front flange to the sliding section front uj and hey presto you have a single piece prop for mk2 escort and mt75 gearbox. see if you can get a transit prop measured us as cant remember what wheelbase one it is that you need. I ran mine like this for a while but as it was off an old transit it was needing ballenced so i then took that opertunity to swap to a heavier duty one made by 105speed.
    hope that helps
  38. #38
    Jul 2014
    aberdeen
    35
    URL=http://s637.photobucket.com/user/ksuds89/media/20130721_131559_zpsa36daadc.jpg.html][/URL
  39. #39
    Jul 2014
    aberdeen
    35
    Well the escort has recently undergone a small rebuild / upgrade to a new T04e turbo and AEM thruboost controller along with a cometic head gasket to deal with the boost :-)
    Also made the trip across to stornoway for a spot of drag racing
  40. #40
    May 2004
    Norn Iron
    1,142
    Cool...but buy a new air filter lol
