Results 1 to 12 of 12
Thread: Old Merc, the daily driver
    Dec 2008
    Finland
    35
    376
    Hi!
    Just thought that if somebody is intrested I could show my current daily driver which I builded in 2013 around 9months. It has now 19000km on the clock with current setup.
    Many pictures here, so try to cope with them
    So this is Mercedes-Benz W123 from year 81'. It had 200 gasoline engine and almost no options at all from the factory
    It required months of to get it all solid again. Changed front fenders, rear side's, whole back panel etc etc..
    Some cutting here (just couple of the places):
    After that little paint to all the pieces (same original color of course)
    The power comes from OM606 diesel (W210 300 turbodiesel), with 320CDI 5speed automatic electrically driven box which I did repair and make it stronger also.
    And here is the finished engine bay
    Intercooler needed some thinking to get it fit and still be unvisible from front. Finally did find out clever way to make it:
    Boost pipes go inside the chassis rails and comes up in the engine bay:
    Is very hard to get lsd rear end in this, so I decided to put TYP210 LSD from E36 M3 to original subframe. Needed custom driveshafts with e36 outer joints and inner joints from T4 Transporter
    Front brakes are from 500SEC W126, they are bolt on. Original ones are 278x12.7mm and new ones are 300x28mm.
    Transmission and engine oil coolers are mounted on front of the wheels, couldn't find room from anywhere else
    Radiator (by griffin) is the biggest one I could fit without grinder
    Me and my friend decided that we don't have any better to do at the weekend, so we went to my work place and result was a Stainless exhaust with 4" downpipe and 3" double exhaust to back with one silencer. Couple vids in the end..
    I made my own dash with speedhut meters, turned up nice! It has 1mm cabron plate where all the instruments are mounted.
    Rims are made by myself from original 14" Barocks to 3pcs 16" rims. They are 8,5x16" in the front and 9,5x16" at the back with 205/50 and 225/45 tyres.
    So here are to biggest things from this daily driver.. It also has gaz adjustable dampers on all corners, bmw steptronic gear leveller, pcs transmission controller and many other things.. Ask if you have anything on your mind about his car.
    How the car looks now:
    Oh, I did dyno this also (rear wheel output only in the pic)
    You can look more pictures from here: http://sultzi.kuvat.fi/kuvat/MB+W123+-81/
    Couple vids I promised:
    https://www.youtube.com/watch?v=d1bH...nNVhf2i1N_9nwA
    https://www.youtube.com/watch?v=2HVa...nNVhf2i1N_9nwA
    https://www.youtube.com/watch?v=Ml7G...nNVhf2i1N_9nwA
    And if moderatos find this to be in wrong place, let me know..
    Jun 2006
    kilkenny, ireland
    519
    Re: Old Merc, the daily driver
    Great stuff, love it, ive always wanted to fit one of these engines to a W123 estate.
    Tell me more about the transmission controller...?
    Mar 2011
    Highley, Shrophire
    412
    Very smart, some good work gone into that!
    9,211
    i love the whole concept of this
    Dec 2008
    Finland
    35
    376
    Thank you guys
    Transmission controller is PCS TCU-2000, which can be used virtually with any electrically driven tranny. I can adjust pressures, shift times etc etc. It also works in automatic mode, just needs adjusting. I have been running full manual mode, just use the stick to shift up and down. Car speed comes from that bmw rear differential to pcs, so automatic mode works also. Just haven't adjusted all the shift change speeds etc.. Turbo is a bit big for this low output, so big turbo lag is reality with this
    Mar 2007
    Hartwell
    166
    Very cool project and love the stance it has .... what mods if any have you done to the engine to get to that power output ? I know there a very strong unit and very popular. I wouldn't think its as easy as putting a big turbo on and cranking up the boost ....
    Dec 2008
    Finland
    35
    376
    Engine just needs bigger turbo, better injection pump and that's it really. Just a lot of food and boost for the engine needed
    Nov 2011
    Glos
    904
    23
    Very nice car with great work gone in to it.
    Dec 2008
    Finland
    35
    376
    And now the engine, drivetrain etc are sold, chassis will get new more intresting engine in the future, but first I need to fix couple Fords back to road
    Oct 2016
    Budapest
    Hello to all our members, I am a new registered, thank you for being here!
    Hello. I saw the 5-speed automatic transmission has been dumped in the W123.
    I want to ask that the control of, how did you do it? I have an om-W126 is equipped with al-OM606, I also want to do such a converter
    Thank you in advance for your answer!
    My email: zoltan.tokesi@gepjarmuhely.hu
    If need, the my facebook: https://www.facebook.com/zoltan.tokesi
    Yours sincerely, Zoltan Tőkési.
    Jul 2009
    scotland
    67
    29
    Stunning car , what an amazing amount of work ,well done
    Bodger capri dave's Avatar
    Sep 2009
    A, A
    136
    lovely car
    http://www.scooternations.com/
