Results 1 to 10 of 10
Thread: small hole top mount choices?
    Oct 2011
    Antarctica
    163
    ive looked at sooo many different ones, does anybody have pic of what left the factory, rs2000 mk2 small hole mounts look like?
    and what are my options of fitting new ones? do u get roller bearing rubber type mounts? i hear the solid alloy type are too harsh for road use.
    small hole
    Re: small hole top mount choices?
    Std small top mounts were all the same - look at any std escort.
    Alloy top mounts will be harsher than std or the original RBTM's that ford used as both have a rubber part. Having said that, many do use alloy ones on the road.
    I am sure I have read somewhere of people using mk7 escort top mounts with an adapter sleeve on small hole escorts.
    3,641
    You don't get small hole rubber RBTM's, only alloy.
    Oct 2008
    nairn, scotland
    71
    9
    i used Corsa B alloy eccentric top mounts for camber adjustment on my small hole RS2000. i found that they were pretty harsh on the road so i bought some nitrile oil resistant black rubber from ebay about 5 or 8mm thick and made a big gasket to sit between the body and the top mount and it made a huge difference, far better in my opinion.
    3,641
    Quote Originally Posted by louis31 View Post
    You can buy alloy small home eccentric mounts, why use corsa ones?
    Oct 2008
    nairn, scotland
    71
    9
    I had the corsa ones in my garage and was surprised they fitted
    Jan 2006
    ireland
    183
    36
    Just to revive this old post.
    We have just made a batch of Rubber top mounts to suit the small hole strut tops,
    More info here
    http://grp4fabrications.com/product_...oducts_id=1321
    http://grp4fabrications.com/product_...oducts_id=1322
  8. The Following User Says Thank You to mojo For This Useful Post:
  9. #8
    Plymouth
    899
    they now do the rubber roller top mounts for small hole inner wings
  10. #9
    3,641
    Now theres a long awaited product
  11. #10
    Jan 2006
    ireland
    183
    36
    plenty in stock a the moment too.
