Results 1 to 8 of 8
Thread: FIA Master Switch Wiring Diagram ?
    Oct 2001
    DERBY
    682
    Does anyone have a wiring diagram for a FIA master switch as i seem to have lost mine an need to complete the wiring og the car
    Cheers in advance.
    Mechanic Bob2's Avatar
    May 2003
    Surrey
    559
    Re: FIA Master Switch Wiring Diagram ?
    According to my instructions
    3ohms 11 watt resistor left of 1
    Main electrical feed right of 1
    Ign Coil left of 2
    ign switch right of 2
    The 1 & 2 should be stamped on the base with the four terminals hope that helps
    Oct 2001
    DERBY
    682
    Not really, as mine aint labelled up as 1 or 2.....its a Z and W i think.....
    booooolllox....might just buy a new one
    Racer Decade Plus User Sideways's Avatar
    Aug 2002
    The hole on earth they call Cheshire
    2,136
    Right, copied from my rallycar....
    obviously the two main ones are for battery cables
    the terminals marked "Z" is for the ignition feed,
    the terminals marked "W" or "M" depending what way up you look at it, needs to be wired one side to the +ve supply(when the switch is on)and the other to side to earth through a 3 ohmn resistor.
    doesn't mater which side is which as it works either way.
    I have a diagram @ work which explains it better but I'm off this week
    HTH
    Steve
    Oct 2001
    DERBY
    682
    so as the key is turned off, points to 9 oclock, when its on its a @ 12....
    which goes to battery and which to starter top or bottem terminal ?
    Aug 2002
    2,136
    either, take your pick, it doesnt make any difference
    mine is on @ 9 o'clock and off at 6 o'clock which makes the battery terminals 3 and 9 o'clock with Z @top and W below, when viewed from the back.
    just need to remember to wire one of the "W" terminals to the side that is live ony with the switch in the on position.
    Steve
    Oct 2001
    DERBY
    682
    kinda makes sense, will have a look tonight as i can't remember what it looks like
    finished the mk2 loom tho, just used about 10% of original loom which is cool
    Aug 2002
    2,136
    cool
    Steve
