Results 1 to 10 of 10
Thread: Transit injectors
    Aug 2012
    lampeter
    284
    Transit injectors
    My transit 2002 transit it needs new injectors if I get recon set will I have to get them programmed its a 2.0 tddi
    Jan 2005
    essex
    65
    Re: Transit injectors
    No , only tdci
  3. The Following User Says Thank You to lukehins For This Useful Post:
    Feb 2009
    essex
    1,986
    Quote Originally Posted by dorianwills View Post
    whats it doing to make you think it need injectors ?
  5. #4
    Aug 2012
    lampeter
    284
    Got sum white/blue smoke stinking of fuel
  6. #5
    Feb 2009
    essex
    1,986
    have you had the egr valve out and cleaned it that will kick smoke out when you drive it is it flat ?
  7. #6
    Aug 2012
    lampeter
    284
    It smokes bad on start up no not yet will that cause blue smoke what do you mean by flat it also juders if you hold it at same speed
  8. #7
    Feb 2009
    essex
    1,986
    be carefully because them engines like a timing chain it wears the bottom guild away .what you can do is a leak off test before you remove them because it may be its only one injector fault
  9. #8
    Aug 2012
    lampeter
    284
    Haw do you do leak off test
  10. #9
    Feb 2009
    essex
    1,986
    your need to find someone with a leak off kit because there is no point buying a kit to use once
  11. #10
    Feb 2009
    essex
    1,986
    sorry what you do is put it on the bottom pipe on the injectors that's the leak off that goes back to the tank
