starting problem
I have 90 spec rst that starts for about 10 secs then dies out, also it does not respond to the throttle. Can anyone help me PLEASE? <font color="blue"> </font>
Re: starting problem
There is a yellow censor on the back of the inlet manifold check that it is connected.
You will not be able to see it just feel for it on the left hand side underneath the cold start injector.
This could be a lot of things, got any more details? What checks have you done? My first check on a car that age would always be that the coolant sensor is conected properly, they don't like running without them.
ive got the same problem,, have u checked that ur fuel pump is workin? have u replaced the pink fuel relay?
i have this problem it will start.. then soon as u touch the throttle it dies!?!? ive bin told it could be the cold start injector? i checked mine at work n theres only power being sent to it for a split second? if u cure it let me no what u did! mite work for me haha
iv just replaced the fuel relay,, problem sorted!
