Cossie Prop Shaft
Hi, what prop shafts have you all used, i've got a t5 box and an atlas axle?
Re: Cossie Prop Shaft
Ive had mine made like I assume most would have too.
Cheers, Yodz
A RS2000 single piece shortened slightly depending on which crossmember you use.
For a decent WXCM like the one from Rally and Competition Equipment you need 1.5" inches shorter, but double check as they all come up slightly different lengths, just measure from the tailshaft of the gearbox to the diff flange with the car loaded on its wheels to work out.
Mark
would this be the same for a MK2
Tony
Just to Ad,
I had to have mine shortened by 2 1/2" but i used a Peter Lloyd Ralling Crossmember, Wish I'd known about the squires ones before i started, but i went on Price, Turns out you get what you pay for again
cheeRS.................Ken
As said always check first as there are so many variables to this length.
How's your's coming on Ken?
