Results 1 to 10 of 10
Thread: what ECU will work with factory trigger wheel ?
    Jun 2008
    Dunfermline, Fife
    459
    62
    hi all
    looking at ECU options for my S2000 chevette project, dont really want to go down the route of having to fit an external trigger wheel so looking for an ecu that will work with the factory trigger wheel set up, my engine is an 03 plate
    has anyone got any suggestions ? id like to go Emerald as ive never had an Emerald before, has anyone used these before with S2K ?
    many thanks
    Finlay
    23,834
    234
    Re: what ECU will work with factory trigger wheel ?
    ive used them on loads of things, in fact i supply them, ive personally never used one on an s2000, BUT ive seen loads mapped on emeralds rollers
    Jun 2008
    Dunfermline, Fife
    459
    62
    Can u remember If they had external trigger wheels on the crank pulley ?
    23,834
    234
    Nope but i will make a phone call in the morning if i remember
  6. The Following User Says Thank You to Graham For This Useful Post:
  7. #5
    Jun 2008
    Dunfermline, Fife
    459
    62
    That would be awsome if you could, cheers
  8. #6
    Sep 2006
    Isle of Man
    293
    I have an R.E.D ecu which uses a standard trigger wheel, and we have run the ecu on a car with the standard plenum set up also.
  9. The Following User Says Thank You to bones For This Useful Post:
  10. #7
    Jun 2008
    Dunfermline, Fife
    459
    62
    Ive sent RED and email, see what prices he comes back with, did he mod the engine loom for you also ? Id also like to use the lcd dash, did you retain that with the RED ecu ? Cheers
  11. #8
    2,293
    Just had a quick look and DTA ecu's will work with stock S2000 sensors, crank and cam sensors.
  12. #9
    Mar 2011
    Highley, Shrophire
    30
    412
    R.E.D. ie John Beattie has just remapped my s2000 lump in the escort after going from the plenum to throttle bodies, runs like a dream! That is on an RTD ecu which John has used for years.
    They do a wiring loom, you supply your s2000 engine loom and they build a new loom from that.
    They also do the dry sump kit etc.
    My car has all these bits and it's all good!
    They are quite old school though, might be worth giving them a call if you don't get a reply by email
  13. The Following User Says Thank You to Craig89 For This Useful Post:
  14. #10
    Jun 2008
    Dunfermline, Fife
    459
    62
    Cool thanks for info
