Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 41 to 80 of 277
Thread: MK1 Duratec
  1. #41
    Sep 2006
    Bedfordshire
    327
    33
    Re: MK1 Duratec
    Quote Originally Posted by eric View Post
    The chassis mounts are next on the jobs to do list, going to drop the engine a tad closer now
    Just weighing up the options to chassis mount or x member mount with the lowered rack,
    hmm
  2. #42
    Re: MK1 Duratec
    Quote Originally Posted by doughman View Post
    hmm
    If things go to plan this weekend I will be posting up pics of the mounts clearance etc
  3. #43
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Just found the ad from when I bought it from Matt. Clint built it or had it built. £150.
    http://www.turbosport.co.uk/showthre...=Duratec+parts
  4. #44
    Dec 2013
    kent
    82
    Re: MK1 Duratec
    [QUOTE keep up with duratec powered escorts on the track.
    Mmmm I must learn how to do you tube.
  5. #45
    Re: MK1 Duratec
    Quote Originally Posted by goldy View Post
    And a certain mk2
  6. #46
    Tyre Kicker svein egil's Avatar
    Dec 2007
    Norway
    23
    Re: MK1 Duratec
    I would recommend an oil tank that can be filled with 7-8 litres before
    it become half full. Otherwise you will need a rather big oil cooler....
    On my dry sumped Duratec I use a total of 9 litres of oil, and the tank is slightly over mid full.
    And I can keep my oil temp below 90 degrees even on sunny trackdays.
    Just my recommendation.
    And don't forget a good catch tank either. Mine is two litres, just to get rid of all the air in the oil and to get the oil pump to breathe properly.
    Remember that the engine will have pretty much vacum because of the dry sump system.
    Great car you have btw..!!
    Svein Egil.
  7. The Following 2 Users Say Thank You to svein egil For This Useful Post:
  8. #47
    Dec 2013
    kent
    82
    Re: MK1 Duratec
    And a certain mk2
    Will the duratec keep up ?
  9. #48
    Re: MK1 Duratec
    Looking forward to finding out should whip the old pintosaurus, if not I will probably take up knitting
  10. #49
    Dec 2013
    kent
    82
    Re: MK1 Duratec
    Don't get your hopes up.....I will get you some wool
  11. #50
    Re: MK1 Duratec
    Update on this weekends progress, final engine alignment angle x-member height etc sorted and chassis mounts all welded up.
  12. #51
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Are the mounts angled down???
  13. #52
    Feb 2009
    lancs
    Re: MK1 Duratec
    Nice build
  14. #53
    Re: MK1 Duratec
    Quote Originally Posted by trig View Post
    No pretty much level, the height of the chassis mounts and engine determined where the angle of the tube finished at
  15. #54
    Re: MK1 Duratec
    Quote Originally Posted by marcp View Post
    Nice build
    Thanks mate
  16. #55
    Dec 2008
    Finland
    35
    376
    Re: MK1 Duratec
    I have pretty much angled down, wanted the engine as low as possible But mine is 30cm more back than original, so xmember will be in front of the engine
    Keep it up.
  17. #56
    Nov 2012
    south of france
    29
    Re: MK1 Duratec
    nice job
  18. #57
    TURBOSPORT SPONSOR Turbosport Sponsor
    Mar 2014
    Leeds
    185
    Re: MK1 Duratec
    Got some feed back from a lad that I did a Duratec head for and he reported back to me quoting 13bhp on a totally standard engine. Yours should see a lot more with the modifications been done.
  19. #58
    Re: MK1 Duratec
    Quote Originally Posted by Andrew@ALD View Post
  20. #59
    Re: MK1 Duratec
    Made some more progress this week engine and gearbox alignment now finished and exhaust and steering rechecked before moving on.
    Next on the list of jobs was to get the tunnel sorted
    Used a Rally Weld tunnel in the end fitted ok to the floor but the bulkhead did take some work to get this to look right, pleased with the end result.
    Heated up the bulkhead overlap and ended up with a nice crisp edge, no more struggling with getting the box out anymore.
    Next on list is to weld up all the redundant inner wing holes and make a decision to either set the dry sump tank in the drivers side wing or in the boot
  21. #60
    Jun 2007
    Essex
    10
    Re: MK1 Duratec
    Good project mate!! Very nice!!
  22. #61
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Looking good buddy.
  23. #62
    Re: MK1 Duratec
    Quote Originally Posted by E11OTW View Post
    Looking good buddy.
    Thanks lads, should finish the engine bay welding this weekend and start the prep for paint before it gets to cold.
  24. #63
    Re: MK1 Duratec
    Bit more time on the Escort welded up all the redundant holes on the inner wings and bulkhead area, a much cleaner install as all of the auxiliaries are being transferred to the nearside
  25. #64
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Looking good so far matey.
  26. #65
    May 2011
    Dubai,UAE
    Re: MK1 Duratec
    Lovely project! Keep up the good work!
  27. #66
    Re: MK1 Duratec
    Had the pleasure of stripping the dreaded old stone chip off over the last 2 weekends, there was a patch of stone chip that had reacted to the gearbox oil so it had to come off, ended up stripping the whole floor and inner wings, what time consuming crap job.
    But what it did reveal how good this shell is, don't see many MK1 inner wings as good as these
  28. #67
    Jun 2006
    Durham, UK
    1,494
    Re: MK1 Duratec
    Yep, it's a pig getting that stuff off, but it does do a bloody good job of keeping the dreaded rust at bay - mine was covered in it when I got it, and there was surprisingly little rot.
  29. #68
    Apr 2009
    kent
    20
    Re: MK1 Duratec
    still looks good after all these years , do the top plate repairs I done still look ok Eric now you have stiffened up suspension ?
    gerry
  30. #69
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Run the brake lines inside the bulk head and into the inner wings. clean engine bay.
    Looking go tho bud. Just need to get a nice gearbox to go with the engine now. Lol.
  31. #70
    Re: MK1 Duratec
    Bit more progress, chassis and inner wing to bulkhead strengthening gussets finished, just need to get the brake strengthening brace made up to complete the engine bay welding then get it painted
  32. #71
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Nice bit of progress there bud
  33. #72
    Re: MK1 Duratec
    Thanks trig
  34. #73
    Re: MK1 Duratec
    Due to poxy work commitments only had a few hours on the escort this weekend but was enough to weld in the last strengthening plate, sorts out any bulkhead flexing issues when braking hard.
    If anyone needs this plate I may be able to get some made up
  35. #74
    Re: MK1 Duratec
    Finally got back to the Escort to start the fitting of a 60g gearbox (thanks Trig) needed some cutting to get the gear change housing through the tunnel to sort the engine and prop alignment.
    Going to reuse the std brackets from the old tunnel and with some mods to trigs gearbox mount should work well
    These boxs are advertised as a direct replacement for a type 9 not convinced on that one
  36. #75
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Good work so far. How much power do you expect with the new engine
  37. #76
    Re: MK1 Duratec
    Quote Originally Posted by Turboman View Post
    Between 240-255bhp at 8000rpm its been built to the spec as a Caterham R500 engine
  38. #77
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Nice N/A power will be some machine to drive when done
  39. #78
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Yeah there's no way these will fit in same hole as a T9 box. Lol.
  40. #79
    Re: MK1 Duratec
    These box's don't look that big until you start fitting them, It will be worth all the effort in the end
  41. #80
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Shore will buddy your love it once it's up and running.
