Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 161 to 200 of 277
Thread: MK1 Duratec
  1. #161
    Re: MK1 Duratec
    Quote Originally Posted by FOSSIE View Post
    Any reason why you put the Laminova in the post-rad (cold) side of the cooling system?
    I did the same - I listened to the pro's and con's for both and this way made more sense to me.
    Although it hasn't had a proper race-test yet, the miles it has done would suggest it's possibly over-cooling - very difficult to get oil up to temperature. Smaller rad perhaps...
    Are you going to mod the radiator so outlet is on same side as laminova?
    The top is the return circuit so the temps in theory will be higher as the water will be heated by the engine before it returns to the rad. I took advise from mocal and a friend who works for Caterham that there should be no problems installed in this way, the only reason I went this route it was a lot easier to install.
    The rad is from my last st170 engine with the inlet and outlet on the nearside made by Radtec it was very efficient and should be up to the task.
    You said you are experiencing low oil and water temps, are you using water flow restrictor that fits into the Laminova and is your water pump ecu controlled.
  2. #162
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Re: MK1 Duratec
    Yeah I agree,
    Engine builders seem to err towards putting the laminova in the hot side, but the only justification I heard for doing this was because it'll pull the oil temp up to operating temp quicker. This is undeniably true, but for a race car that only gets started a handful of times in it's life (compared with a road car) then gently warmed up, I reckoned having cooler water in there, therefore bigger temperature differential, would be of more benefit. Having said that, you're now putting hotter water into the engine! So it's probably a case of swings and roundabouts... The overall cooling capacity is what's important. The main water rad is now actually cooling water and oil, so it has to be big enough.
    Yes my pump is ECU controlled and plenty of scope for adjustment, and there's the option of fitting a restrictor in the laminova, but I'm going to wait for some proper test data before fiddling with anything.
    Anyway, nice build! Lovely installation. Will be keeping an eye on this. Which exhaust manifold is that by the way?
  3. #163
    Re: MK1 Duratec
    It will be interesting to see what oil and water temps are seen when its next used in anger and how efficient the lamanova really is, having only ever used traditional oil coolers its all a learning curve.
    One off the main reasons I like these coolers is the reduced oil warm up time and temp stability.
    Like you say its all down to the main water radiator to control both oil and water temps, its possible I will need a more efficient rad, soon find out once some testing is done.
    The exhaust manifold is a stainless SBD Motorsport item
    one off the best Ive seen for the duratec and backed up with dyno testing
    And thanks for your comment
  4. #164
    Re: MK1 Duratec
    Finally the dry sump system is finished and primed using a air drill, as the oil was drawn through it slowed the air tool but was impressive to see nearly 50psi oil pressure with the pump turning quite slowly.
    The fuel tank arrived from Pro Alloy and was quickly fitted along with the injection pump and pre filter, just need to finish the feed and return and that's the fueling sorted.
  5. #165
    Jun 2006
    Durham, UK
    1,494
    Re: MK1 Duratec
    Very tidy boot install
  6. #166
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Good to see some more progress matey.
    Get it done for March 18th got Combe booked again. 😉
  7. #167
    Re: MK1 Duratec
    Quote Originally Posted by MegatronUK View Post
    Thanks mate
  8. #168
    Re: MK1 Duratec
    Quote Originally Posted by trig View Post
    Get it done for March 18th got Combe booked again. ��
    Have to see nearer the time, what will you be using for Combe
  9. #169
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Fingers crossed my estate.
  10. #170
    Re: MK1 Duratec
    Bit more progress on the wiring front, made a start on the ecu and relay box this will be fitted on the gearbox tunnel, just two wiring connectors and the side clips for easy removal, its a lot of work to source all the parts but will make for a very tidy install.
    This is a variation of a idea from http://www.zetecinside.com/xr2/ who is also a member on this site
  11. #171
    Re: MK1 Duratec
    One more for good measure
  12. #172
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Awesome mate one thing I've never been any good at is wiring.
  13. #173
    Dec 2015
    Frinton on sea
    10
    Re: MK1 Duratec
    Seriously tidy, look forward to seeing it finished
  14. #174
    Jun 2012
    Bristol
    31
    103
    Re: MK1 Duratec
    Can you buy those wiring connectors seperately? I re-routed my capri loom through the wing and was just going to use grommets but those bulkhead fittings would be a much better idea!
    Looking good though
  15. #175
    Re: MK1 Duratec
    Quote Originally Posted by NathanPrince View Post
    Looking good though
    All the connectors are from http://uk.rs-online.com/web/p/products/2735382/
  16. #176
    Jun 2012
    Bristol
    31
    103
    Re: MK1 Duratec
    Cheers, I did use the original Capri rubber bulkhead connectors but they're a bit oldhat, will try getting some of these and do the job right!
  17. #177
    Re: MK1 Duratec
    Thought it was about time to sort out the rear valance been putting this off for awhile, prep and painting is such a time consuming process takes up so much time. So 1st thing was welding the old exhaust position and making a new cutout on the offside.
    Started prepping the panel ready for paint
    Bit of blue sorted glads that's out of the way
  18. The Following User Says Thank You to eric For This Useful Post:
  19. #178
    Re: MK1 Duratec
    Wiring is taking shape now my sons been sorting out the ecu box, its looking good and will tidy up the loom a treat
    Adjustable clutch pedal stop sorted made up with some scrap parts
    And to finish off the engine pulley brackets and belts are all now sorted
  20. #179
    Spanner Monkey Darbo's Avatar
    Nov 2009
    Lancaster
    462
    Re: MK1 Duratec
    very neat aux belt setup
  21. #180
    Dec 2013
    kent
    82
    Re: MK1 Duratec
    Meticulous build .....Duratec or YB lol
  22. The Following User Says Thank You to goldy For This Useful Post:
  23. #181
    Re: MK1 Duratec
    Quote Originally Posted by goldy View Post
    If I had known how much a decent high spec Duratec costs to build I think I've would have gone your new Smith and Jones inspired engine build instead
  24. #182
    Re: MK1 Duratec
    Bit more done today got to play with this beast
  25. #183
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    How much power are you aiming for
  26. #184
    Mar 2011
    Nurburgring
    11
    Re: MK1 Duratec
    Top stuff, very neat and thorough.
    Just a thought; can the ecu overheat/withstand the higher temperatures of being on top of the tunnel? (on the presumption the above picture shows the finalised location)
    Andy
  27. #185
    Re: MK1 Duratec
    Quote Originally Posted by Turboman View Post
    Should be in the region of 245 255bhp I am using the 45 jenveys from my oid setup which will lose some peak power, direct to head throttle body's will probably be fitted at a later date.
  28. #186
    Re: MK1 Duratec
    Quote Originally Posted by 2639 View Post
    Andy
    Cant see a problem with over heating but if the ecu does too hot a pc cooling fan is at the ready just in case
  29. #187
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Quote Originally Posted by eric View Post
    Is there any reason you went for a duratec instead of modifying the st engine further ?
  30. #188
    Re: MK1 Duratec
    I thought that the st had reached its limit power wise to push it further was to expensive, you cant rev the st without oil pump mods etc, I can get the duratec to a easy 260bhp+ with good torque the st engine cant compete.
  31. #189
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Ok thanks for the reply does billet oil pump gears not fix the oil pump issue on the st
  32. #190
    Re: MK1 Duratec
    In my opinion no there is still a risk of oil pump gear failure at high rpm due to crank flex, the only safe option is a dry sump setup. There will be other views on this that the gears have fixed the problem but how many are used purely on the road and not flat out on a race circuit.
  33. #191
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Looking great matey.
  34. #192
    Re: MK1 Duratec
    The Escort has progressed really well over the last month there has been some annoying problems but most of the wiring is now completed including the Dash2 install, seats are in and its starting to look like it might be finished soon. Had some problems with the starter which has now been resolved(helps if you use the right one) water leak from the water pump blank mod and what looks like a dead alternator.
    Some pics of the dash wiring all done by my son Simon who enjoys doing the wiring
  35. #193
    Dec 2009
    Netherlands
    413
    19
    Re: MK1 Duratec
  36. #194
    Apr 2009
    kent
    20
    Re: MK1 Duratec
    Looking good Eric not long now I guess ?
  37. #195
    Spanner Monkey redhf's Avatar
    Jan 2006
    uk derbyshire
    58
    479
    164
    MK1 Duratec
    Are those stickers on that centre console ?
  38. #196
    Re: MK1 Duratec
    Quote Originally Posted by redhf View Post
    No they are etched into the metal
  39. #197
    Re: MK1 Duratec
    Quote Originally Posted by v6gerry View Post
    Hope not gerry
  40. #198
    Jan 2006
    uk derbyshire
    58
    479
    164
    MK1 Duratec
    Who did it for you ?
  41. #199
    Re: MK1 Duratec
    Not me I bought it already done, it was from a group B subaru rally car
  42. #200
    Jan 2006
    uk derbyshire
    58
    479
    164
    MK1 Duratec
    Ok thanks .
