Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 201 to 240 of 277
Thread: MK1 Duratec
  1. #201
    Apr 2009
    kent
    20
    Re: MK1 Duratec
    is it on the Key yet Eric ?
  2. #202
    Re: MK1 Duratec
    Quote Originally Posted by v6gerry View Post
    Nearly ready but Ive had to send the ecu back to Omex to be upgraded as its too old a version to talk to the race technology dash
  3. #203
    Apr 2009
    kent
    20
    Re: MK1 Duratec
    not long then , will have to pop down lydden when its done .
  4. #204
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Top work bud looks great.
    Can I borrow rent your son??
    Gona need my 350 wired in soon.
  5. #205
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
  6. #206
    Re: MK1 Duratec
    Quote Originally Posted by trig View Post
    Thanks trig does yours need a complete rewire if so http://www.carbuildersolutions.com/u...-wiring-module
  7. The Following User Says Thank You to eric For This Useful Post:
  8. #207
    Apr 2009
    kent
    20
    Re: MK1 Duratec
    im thinking of using that wiring module on mine when I redo the loom it looks very simple ,
  9. #208
    Re: MK1 Duratec
    Its a lot easier to use the module if starting from scratch, they are also available with the wires and labelled up ready to install
  10. #209
    Re: MK1 Duratec
    This weekends progress was a bit hit and miss, the ecu was returned from Omex after a chip upgrade but has now has a map upload problem, so that has put a hold on the planned 1st start
    On the upside the water leak is sorted and all primed up, also the fuel lines have been flushed and tested for leaks all good so far.
    The EWP80 water pump controller is next on the the too do list, the water flow looks too fast wired up with just a on off switched feed, so my resident wiring expert is on the case and made this.
    It's an Arduino Uno micro controller, started off with a 30amp PWM motor board but then changed to a 10amp PWM motor shield to make it smaller
    At the moment the code gives out 6v until the temp gets to 90c or above and then ramps up to 12v. It also reads the temperature once every second. The code can be altered too suit different running characteristics and can be calibrated for most two wire sensors
  11. The Following 2 Users Say Thank You to eric For This Useful Post:
  12. #210
    Re: MK1 Duratec
    Big step today the engine is up and running for the 1st time , got to be one of the noisiest Ive ever heard with the combination of a race clutch and 60g rattling away
    https://www.youtube.com/watch?v=fdrRCdH3ykk
  13. #211
    Aug 2006
    Christchurch, New Zealand
    463
    Re: MK1 Duratec
    Quote Originally Posted by eric View Post
    Fantastic, sounds brilliant
  14. The Following User Says Thank You to Pikey15 For This Useful Post:
  15. #212
    Spanner Monkey SimonD's Avatar
    South East Kent
    230
    22
    Re: MK1 Duratec
    Another video from the Sunday
  16. #213
    Re: MK1 Duratec
    great job well done. great thread
  17. The Following User Says Thank You to wildo105e For This Useful Post:
  18. #214
    Re: MK1 Duratec
    Thanks mate have to do a video with my foot on the clutch pedal so you can hear the engine
  19. #215
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    😝 ah miss that noise sooooo bad. Good to hear again even if it ain't my car. 😢
  20. #216
    Dec 2008
    Finland
    35
    376
    Very nice, always great feeling when you get long project running! Cant wait to get my duratec running, long way thought..
  21. #217
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Any progress has it been on the rollers yet ?
  22. #218
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    This done yet?
  23. #219
    Re: MK1 Duratec
    This done yet?
    It is I do a update at some stage got to say that gearbox is spot on suits the Duratec the only thing its so noisy I am having to put in a intercom system in
  24. The Following User Says Thank You to eric For This Useful Post:
  25. #220
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Fair play bud I miss that engine and box so bad but the £££ in it just for playing about with was silly to keep it really specially as it was sat in a £400 shell lol.
  26. #221
    Re: MK1 Duratec
    Does seem at bit ott but you had some good times with that £400 shell
  27. The Following User Says Thank You to eric For This Useful Post:
  28. #222
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Very true bud and the new ones done and sounding great.
  29. #223
    Re: MK1 Duratec
    Do you have a build thread
  30. #224
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    On Facebook bud.
    It's too hard to upload large pics on here now.
  31. #225
    Mar 2003
    TRURO
    5,250
    246
    Re: MK1 Duratec
    Its not hard to make em smaller tho come on get some pics up not all of us are on facefuck...
  32. The Following User Says Thank You to meXEco For This Useful Post:
  33. #226
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    I'll start a thread a post a shap shot of the build but I've got over 1000 pics on the build.
    I think you can view it even if you not on face book.
  34. #227
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Nope just tried it.
    I use tapatalk to post pics now.
    That's much easier 😉
  35. #228
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Started a thread 😉
  36. #229
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    I've just booked a track day at Combe for the 11th November so there's a date for testing for you.
  37. #230
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Come on then been 6 month since last update.
  38. #231
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Track day booked at Combe 24th march. 😉
  39. #232
    Re: MK1 Duratec
    Where did that time go, quick update then.............
    The Escort finally made it to Track and Road to be mapped, Steve asked the engine spec and 240 to 250bhp was agreed to be a realistic target, after a few hours the Duratec was run in and then started the power runs.
    1st run it made 230+ more mapping and swearing from steve over the cam duration and high compression went to a easy 250bhp and ended up at just under 270bhp with 185lb torque at 8400rpm, it was a still making power at even higher revs but was agreed not to push the engine any further than 8400rpm, well pleased with a engine that I built in the kitchen
    At the moment a 46.5 Atlas is in the process of being built to replace the english and is nearly sorted
  40. The Following User Says Thank You to eric For This Useful Post:
  41. #233
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Just about the same as mine then. 😎 your gona love that mate.
    I got a track day at Combe booked for 24march if you fancy that I'll do you a little discount too.
  42. #234
    Re: MK1 Duratec
    Just about the same as mine then. �� your gona love that mate.
    Thanks for the offer trig, I am at Spa close to that date with a R1 MNR have to see if I can get your way later on in the year. There is a sprint with the Borough 19 club at Lydden in July which I hope to go too, should be good fun
  43. #235
    Sep 2006
    Bedfordshire
    327
    33
    Re: MK1 Duratec
    Absolutely lovely car this! Fantastic work from you and your son. A real credit to you with the attention to detail. An inspiration to me (currently trying to install a duratec myself). If mine looked 10% as good as this I'd be happy.
    Does the bottom hose out of the tank run to the fuel filter then injection pump?
    And the top hose on tank is the return?
    I think I'll run a swirl pot on mine too, do you suffer any lose of pressure?
  44. #236
    Re: MK1 Duratec
    Quote Originally Posted by doughman View Post
    Thanks for the positive comments.
    Yes the bottom is the feed to a pre filter then to the pump and returns to the upper connection, I did use a swirl pot when I had a std fuel tank but is not required with the Pro Alloy tank this is due to having a internal collector which acts as a swirl pot. Fuel pressure is always constant but I do use a very good regulator.
  45. #237
    Jul 2006
    bristol
    10,882
    892
    MK1 Duratec
    Trig's Escort Estate Drift Car.
    https://r.tapatalk.com/shareLink?sha...2&share_type=t
  46. The Following User Says Thank You to trig For This Useful Post:
  47. #238
    Thumbs up Re: MK1 Duratec
    Quick Update axle upgrade........
    Atlas axle is now fitted replacing the English, built from a 2.0 Capri axle cut down to 46.5 running a rebuilt ZF 3.75 diff, Grp1 18 spline halfshafts from Race and various bits to finish mainly from Gartrac.
    Fwe pics off the build
    8x13 fit with no clearance problems tyres at the moment are 205/55/13 Avons should be enough space to run 215s
  48. #239
    Re: MK1 Duratec
    ZF was checked only one thrust washer was required not bad for a old Capri ZF
  49. #240
    Re: MK1 Duratec
