Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 241 to 277 of 277
Thread: MK1 Duratec
  1. #241
    Re: MK1 Duratec
    cant believe i missed this update, more great work. This must be one of the best escorts on the streets now.
  2. The Following User Says Thank You to wildo105e For This Useful Post:
  3. #242
    Spanner Monkey Pikey15's Avatar
    Aug 2006
    Christchurch, New Zealand
    463
    Re: MK1 Duratec
    Quote Originally Posted by eric View Post
    Quick Update axle upgrade........
    Atlas axle is now fitted replacing the English, built from a 2.0 Capri axle cut down to 46.5 running a rebuilt ZF 3.75 diff, Grp1 18 spline halfshafts from Race and various bits to finish mainly from Gartrac.
    Fwe pics off the build
    8x13 fit with no clearance problems tyres at the moment are 205/55/13 Avons should be enough space to run 215s
    It's looking great and well done with the engine, you must be well chuffed with that
    Sorry for the stupid question but out of curiosity what are you welding/making in the images above?
  4. #243
    Re: MK1 Duratec
    I aasumed it was a jig to prevent movement whilst welding in the axle tubes ??
  5. #244
    Re: MK1 Duratec
    Quote Originally Posted by Pikey15 View Post
    It's a axle spreader to make the diff easy to remove
  6. The Following User Says Thank You to eric For This Useful Post:
  7. #245
    Re: MK1 Duratec
    Quote Originally Posted by wildo105e View Post
    No jig was used the tube ends were turned down to a interference fit pressed in alignment checked and welded, then rechecked no straightening was needed after welding.
  8. The Following 2 Users Say Thank You to eric For This Useful Post:
  9. #246
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    773
    114
    Re: MK1 Duratec
    Love this project. Great attention to detail. Any updates with the axle fitted?
  10. #247
    Jan 2013
    Barbados
    12
    Re: MK1 Duratec
    Where did that time go, quick update then.............
    The Escort finally made it to Track and Road to be mapped, Steve asked the engine spec and 240 to 250bhp was agreed to be a realistic target, after a few hours the Duratec was run in and then started the power runs.
    1st run it made 230+ more mapping and swearing from steve over the cam duration and high compression went to a easy 250bhp and ended up at just under 270bhp with 185lb torque at 8400rpm, it was a still making power at even higher revs but was agreed not to push the engine any further than 8400rpm, well pleased with a engine that I built in the kitchen
    At the moment a 46.5 Atlas is in the process of being built to replace the english and is nearly sorted
    Hi, this is a reaaly clean & attention to detail example of what I would like to acheive. What was the engine spec? Thought I missed it but I went back through the thread you never gave the details... I'm curious.
  11. #248
    Re: MK1 Duratec
    Quote Originally Posted by iceman.bb View Post
    All tried and tested stuff, brief spec is
    2.0 ST150 engine
    Lightened with a full engine balance using the std crank, all the main bolts are ARP
    Manley conrods with Supertech pistons 1st oversize
    Flowed head std valves D-TEC35 Kent cams
    45mm Jenveys with a SBD exhaust manifold with a 3 inch system
    Dry sumped electric water pump
    7 1/4 Race clutch
  12. #249
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Re: MK1 Duratec
    each time I dropped into that build, I said to me, what a great car.
    And a really nice build, a lot of shared info's. cool
  13. #250
    Re: MK1 Duratec
    I am going through the back end on my car at the moment what springs did you use ? Are they 2inch lowering blocks as well.
    Many thanks
  14. #251
    Re: MK1 Duratec
    Many thanks
    I use decambered 2.8 Capri springs with two inch lowering blocks, Gartrac did the springs.
  15. The Following User Says Thank You to eric For This Useful Post:
  16. #252
    Part of the furniture Decade Plus User trig's Avatar
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Ah up not been on here for a while and first thing I see is a update of your car
    good you see your still going on it buddy hows that old box holding up?
  17. #253
    Re: MK1 Duratec
    Quote Originally Posted by trig View Post
    Hi Trig, the 60g is all good, its coming out for a service at xmas and fitting a load cell to smooth out the Geartronics flatshift. Now running a 2.4 Duratec.
  18. #254
    Jul 2006
    bristol
    10,882
    892
    Re: MK1 Duratec
    Sweet
  19. #255
    MK1 Duratec
    Think we need an update 👍
  20. The Following User Says Thank You to wildo105e For This Useful Post:
  21. #256
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Will there be updates on the next evolution of this amazing car
  22. #257
    Re: MK1 Duratec
    Quote Originally Posted by Turboman View Post
    Thanks for the comment, I will try to do a update over xmas don't get a lot of time at the moment due to a new project underway
  23. #258
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Thanks for reply the mk1 is one stunning I enjoy reading about its progress
  24. #259
    Re: MK1 Duratec
    Ooops 2 threads to write now
  25. #260
    Jan 2019
    Durban, South Africa
    Re: MK1 Duratec
    That is fantastic power Eric !!! I have built a very similar spec engine to yours but have had many people comment that the 12.5:1 compression ratio is way to high for the Kent DTEC35 cams and also I will not be able to run the motor on 95 octane gas without risking pre-ignition.
    It is great to see your engine "proves them wrong" which is a great relief to me. I was wondering what your ignition advance setting are and if you have had any issues with the engine.
    Well done again on a FANTASTIC Mk1 build, the car looks brilliant.
  26. #261
    Racer Decade Plus User dazzle's Avatar
    Mar 2003
    Now over the pond North side
    51
    3,540
    13
    Re: MK1 Duratec
    Would really like to hear about the 2.4 engine?
    Dazzle
  27. #262
    Spanner Monkey Ruudje's Avatar
    Dec 2009
    Netherlands
    413
    19
    Re: MK1 Duratec
    Quote Originally Posted by dazzle View Post
    Let me know if youre selling the pinto
  28. #263
    Sep 2006
    Bedfordshire
    327
    Re: MK1 Duratec
    2.0 ST150 engine
    7 1/4 Race clutch
    Just out of interest why did you use this combination of pistons and rods?
    There’s a lot of options and brands out there I just wondered what your thoughts were?
  29. #264
    Re: MK1 Duratec
    Quote Originally Posted by doughman View Post
    I used the Manley rods because of good reviews and a good price, likewise with the Supertech piston. The 2.0 Ltr was stripped down last Xmas checked over with no problems all good to go again.
  30. #265
    Sep 2006
    Bedfordshire
    327
    Re: MK1 Duratec
    Okay, thanks. How often do you think it would need to be stripped and refreshed?
    So where’s the details on the 2.4?!
  31. #266
    Re: MK1 Duratec
    All depends on the usage if it's a road car and not used on the track, no more than std maintenance required. if you do track days and run the std sump system then every year would be advisable. Use good oil and change the oil a minimum of every other track day.
    I will sort the details of the 2.4 shortly
  32. #267
    Re: MK1 Duratec
  33. #268
    Sep 2006
    Bedfordshire
    327
    Re: MK1 Duratec
    Yea get the link sorted
  34. #269
  35. #270
    Re: MK1 Duratec
    that sounds awesome especially with G60 gear shift so quick.
    Nice
  36. #271
    Sep 2006
    Bedfordshire
    327
    Re: MK1 Duratec
    The Facebook link still doesn’t work?
    Liking that dyno vid, the engine sounds like a monster. What power did you make?
    Have you any track days or shows planned this year?
  37. #272
    Dec 2013
    kent
    82
    13
    Re: MK1 Duratec
    Eric will be at the BHP Show june 6th 2019 Lydden Hill on track with 24 other Retro Classic cars
  38. #273
    Re: MK1 Duratec
    Quote Originally Posted by goldy View Post
    That's the plan just need to finish the 60g service and good to go
  39. #274
    Dec 2011
    Cowdenbeath
    400
    32
    Re: MK1 Duratec
    Any updates on the car what power did the 2.4 engine make and how does it compare to the 2litre it replaced
  40. #275
    Re: MK1 Duratec
    There are more future plans for the Mk1 but its all on hold due to a Mk2 build in progress. The 2.4 has much more torque than the 2.0 170lb, 240lb of torque for the 2.4
  41. The Following User Says Thank You to eric For This Useful Post:
  42. #276
    Re: MK1 Duratec
    Hopefully starting work again on the Mk1 in March as my son's mk2 should be a rolling shell by then, planned work for the mk1 is.......Turrets, wide 4 link kit decent coilovers, and adjustable watts tower, hopefully this will stop the mk1 trying to kill me when driven in anger.
    Never had the pleasure of fitting a 4 link and Turrets should be a fun learning curve
  43. The Following User Says Thank You to eric For This Useful Post:
  44. #277
    MK1 Duratec
    Can’t wait for updates 👍
