MAN I hate to rust protect my car :-( :-(
It's a shitty job and it don't make the car run any quicker at all............ well there is no rust in the car, that's a really good thing
I'm not half done and I've already used 4 liters......so I have to get 8 more liters tomorrow!! (4 liter in each plastic can).!!!!
I have used a couple of days to make a better system than the ones you can buy for DIY use!
The airgun type I have for spraying fluids is made for 8 bars of pressure.
ALOT of air passes over the fluid and it's picked up in the vacum..............that is not good for rust protection spraying, because it vaperrise (hmm spelling ) the oile guuu, and makes it easy for me to breath in the stuff!!
So I made a low pressure system where I put now more than 0.5 bar air pressure in the spray can forcing the oil out and over in an other airgun used only as on/off before leading it in the nylon tube. I made a new jet myself because the original item were for say 8 bars and this is for 0.5 bar pressure.
It looks very UGLY,- but it works
The MOST ugly part of this operation comes here:
Yep I found a timer on the camera.....BUY It's the lens making me look ugly
I'm half done doing the inside of the chassic with the probe thingy, see if you can spot the one place where sticky stuff is dripping out ?:
Cheers Kennert
