Rear Shocks
On my MK1....
I have lowered the suspension quite a bit....
I now need shorter shocks.
Questions are what/ where do I get them from.
When U turret a car in the rear are u guys using the same shocks. I notice some of the diff brackets, for them, fit on the front/rear of housing whilst others fit on top of diff housing.
Would u not use a shorter shock for this style ?
Any ideas help appreciated.
Re: Rear Shocks
I don't know which dampers from another car would fit a really low Escort - Leda would certainly make some specially - but they would be REALLY expensive.
As to Turreted dampers - the short square turrets can use a standard Mk2 style (pin and eye) damper, but the taller round turrets (the top of which are nearly level with the parcel shelf) use a longer damper or a complete coil over unit.
HTH
Re: Rear Shocks
You can use Cossie rear shocks if you hace the long turrett type.(coil over)
