Results 1 to 6 of 6
Thread: What diff ratio works best with s2k
    Jun 2008
    Dunfermline, Fife
    459
    62
    Hi all
    Just wondering what diff ratio to go for for my s2k build, was thinking 4.6 ? Any thoughts anyone ?
    Finlay
    Bodger evobda2's Avatar
    Sydney, Australia
    180
    Re: What diff ratio works best with s2k
    Depends what your using the for etc. Obviously rally 4.6 might be ok, but for road or track I probably wouldn't go that high.
    Remember escort wheels (if thats what your putting it in?) are smaller diameter than standard s2000 wheels.
    S2000's ran a 4.1 usually. Id start with that, bearing in mind the smaller wheel and go from there whether you need longer or shorter ratio.
  3. The Following User Says Thank You to evobda2 For This Useful Post:
    Jun 2008
    Dunfermline, Fife
    459
    62
    Cool, thanks
  5. #4
    Jan 2007
    Weston Super Mare
    1,056
    77
    4.4:1
    Reading through the S2000 forums most modified S2000's change the standard 4.1 to 4.4 to liven them up
  6. #5
    Mar 2011
    Highley, Shrophire
    32
    412
    I run a 4.6 in mine, works fine on the road, considered swapping it to a 5.1 for a bit more get up and go
  7. #6
    Nov 2015
    NZ
    25
    What size wheels are you running and how many rpm does it pull at say 100kph??
