hi all,
Does anyone know the float height (level) for the DCOE Weber with the plastic float? (both values plz, 'max' and 'min')
regards,
Ruud
hi all,
regards,
Ruud
12.5mm with gasket fitted on lid.
You have mail!
Thank you. But,...
That means that the original brass float has the same level as the plastic float .... ?
Did some more research. 12mm and 26mm it is. Although all relate to the brass float...
Ive got this book.
http://www.veloce.co.uk/shop/product...20Modification
Just checked and the 12mm and 26-27mm is correct for plastic floats. The brass floats are 7.5mm and 15mm. Hope this helps. With the gasket in place at all times.
