1997 Suzuki TL1000S £2250...yes £2250...thats more expensive than most. (SOLD)
For Sale ...Located in Essex
Only selling due to emigrating early next year so will not be using this again now the good weather has gone and they will soon be gritting the roads!
Before I write the rest of this ad... I am after £2250 for this bike..yes I know there are dozens available for £1500 (and less)...but I am after £2250 as this is a very very clean bike...does not need anything doing to it...has all the usual upgrades (except rear shock)...has no leaks of any kind, starts instantly, runs 100% smooth with no stuttering etc, this bike is ready to go out on rather than spend its life in the garage being fixed....I have sorted all the little crap jobs that need doing on these....all you need to do is get on it and ride!
1997 TL1000S
Black Metalic
MOT - 18/08/2015
18567 Miles
Last stamped service history at 15205 Miles
Logbook is in my name - acquired 03/08/2013 - (5th owner)
All old MOTs, Service Book, Pre-delivery sheet. Spare key
Bad bits first.
..small dent on tank..about 5mm round, a bigger tank protector would cover it ... £19.99 as per http://www.ebay.co.uk/itm/SUZUKI-TL1...item4d22f4d9f2
Original rear shock..so if you are a Rossi wannabe and think you can outperform a standard shock then its not so good for you...I have never found the rear shocks to be a limiting factor on the road..maybe I'm just too sloowwww.
Good Bits.
Genuine excellent condition bike
ALL the usual niggles have been done
GSXR750 K5 front forks... rebuilt and rechromed ...receipt for £340 (20/06/2014) has done about 250 miles on these!...work done by www.pittedforks.co.uk
new K5 front fender (black FG)
ZX6R Radial Tokico 4 pots (rebuilt/painted)
New pads (EBC £90!!! )
New front brake lines - Black covered Braided twin line setup, stainless bolts, black anodised joints.
Full stainless exhaust system with unmarked Scorpion carbon cans
Rear Hugger
Crashbungs - front spindle and frame spars
Riflemans quick action throttle
Timing Retard Eliminator
Coil + mod
Later Thermostat mod done using brand new thermostat housing, brand new water pump cover.
Plugs changed recently
Air Filter changed recently
Oil/Filter changed at least every 500 miles since I've owned the bike ( I am fanatical about oil/filter changes!)..best thing you can do to give an engine a long life.
Tyres have done less than 1500 miles
Later 2 piece fairing stay fitted (makes it easier to lift tank)
Spares available - original forks, immaculate but do require a build as one of them just will not stop leaking, have tried 2 lots of new seals so there is something wrong else wrong with them.
Original front calipers
Original front fender
Power Commander2 (can be plugged in to prove it works)
Larger Rear Sprocket/Smaller front ... hardly any use
Pair Standard Exhaust Cans
Spare GSXR K5 front fender
So there you have it...no leaky tank, no leaky forks, no underheating/over cooling, no stuttering, no cover leaks.. runs and rides perfectly... bike just needs to be ridden!. I'm after £2250, sorry no PX as there will be no more biking for me :-(
Located in SS6 (UK), no test ride without full cash payment in my hand/proof insurance etc....usual stuff.
Please PM if you are "genuinely" interested... this is a genuine excellent condition bike, not a £1500 project.
Dave
Re: 1997 Suzuki TL1000S £2250...yes £2250...thats more expensive than most.
Lovely bike
Lovely condition
If I had the storage space is have this
Sold
