S2000 Into MK2 Manifold Q
Hello has anyone any pictures of how they managed the exhaust manifold on a Mk2 escort installed with a S2000. Want to modify it as little as possible as the standard exhaust cannot be improved upon,
but steering column is the problem. Thanks guys n gals
Re: S2000 Into MK2 Manifold Q
Here are a couple of pictures of when mine was fitted and although I didn't fit it I believe number 4 needs to be extended by about an inch and number 1 repositioned into the same collector
Hope that helps
The Following User Says Thank You to Craig89 For This Useful Post:
Thank you very much for those pictures those will be a big help. I have the RED set up, Jenvey ITBs, Race Tech Design ECU and dry sump system, can I ask what sort of bhp and torque figures are you getting and from what you are using in terms of ecu, induction etc. Thanks again.
Mine is basically the same as that although I just have the standard Jenvey S2000 kit straight from them whereas I believe RED modify the kit slightly, addition of spacers and use the s2000 injectors.
I wasn't chasing numbers as it is not used for competition but when mapped recently it was 210 bhp at the wheels, that's through the Honda box. I wasn't given torque so I can't help you there but it goes well and drives nice
