Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 121 to 160 of 213
Thread: zetec blacktop alloy water pump pulley
  1. #121
    Jul 2006
    airdrie
    1,549
    Re: zetec blacktop alloy water pump pulley
    Got some more pulleys if any one is still interested
  2. #122
    Jan 2011
    Swindon
    17
    Would it be possible to make this in a smaller diameter?
  3. #123
    Jan 2011
    Swindon
    17
    Sorry, Should have explained:
    I`m looking at driving the Water Pump from the Cambelt Idler.
    Experimented by bolting a pulley to the standard Idler which actually turned the Pump the correct (Anti Clock) direction.
    This worked fine on a track car i had but as the pulley was a smaller diameter than the Crank Pulley, i figured using a smaller W/P Pulley would get the revolutions closer to original.
  4. #124
    Jan 2011
    Swindon
    17
  5. #125
    3,241
    Off topic - but what's the benefit? Or do you run total loss electrics also?
  6. #126
    Jan 2011
    Swindon
    17
    Yeh,
    Been using Zetec in Mazda RX8 but not enough clearance to run the Crank Pulley!
    It`s a Track Car so no electrics to run. Just Water Pump needs driving. Did consider an electric pump but not sure how long battery would last.
  7. #127
    Jul 2006
    airdrie
    1,549
    what size where you thinking m8, i`ll ask the engineer if he could do a smaller one
  8. #128
    Jul 2006
    airdrie
    1,549
    still got a couple of pulley`s left
  9. #129
    Jul 2006
    airdrie
    1,549
    still have some for sale
  10. #130
    Mar 2017
    West yorkshire
    Do you still have any of the pulleys for sale
    thanks in advance
  11. #131
    Jul 2006
    airdrie
    1,549
    yes m8, i`ve a couple left
  12. #132
    Mar 2017
    West yorkshire
    Brilliant, i may require one, i will keep u posted if i do.
    Im currently stuck as to how the alternator and tensioner pulley mount to the black top engine, i have a reverse waterpump impellor to go on and the engine mount has been fabricated, im just stuck as to how the auxiliarys bolt to the engine.
    Any help would be much appreciated.
    Thanks in advance
  13. #133
    3,241
    If you've a reverse impeller then why are you bothering with idlers and tensioner pullies? Simple belt run - crank - water pump - alternator (which is the tensioner).
  14. #134
    Mar 2017
    West yorkshire
    I also have power steering to take into account, i am still stuck on the bt waterpump fouling the original bracket the alternator is mounted to
  15. #135
    3,241
    A picture may help and provide a solution but in the meantime if the PS is required this would be the std layout with idler replacing the PS so not requiring the reverse impeller and lower picture is with all the crap attached - just omit the AC compressor and shorten the belt.Click image for larger version Name:	black top belt run.jpg Views:	175 Size:	25.0 KB ID:	80599Click image for larger version Name:	SAM_0410.jpg Views:	175 Size:	121.7 KB ID:	80601
  16. #136
    Mar 2017
    West yorkshire
    My alternator is front mount, thank you for the pic tho
  17. #137
    3,241
    Front Mount ? ? ?
  18. #138
    Mar 2017
    West yorkshire
    My alternator mounts to the front of the engine, just below the power steering pimp, but the pic you have posted up shows it mounted to the rear
  19. #139
    Jul 2006
    airdrie
    1,549
    Still for sale
  20. #140
    Jul 2006
    airdrie
    1,549
    Still for sale
  21. #141
    Jul 2006
    airdrie
    1,549
    still for sale
  22. #142
    Nov 2017
    Torquay
    26
    Hi mate do you still have any of these
  23. #143
    Jul 2006
    airdrie
    1,549
    yes m8, i have a couple left
  24. #144
    Feb 2018
    Hull
    12
    Hi do you have any left desperately need one
  25. #145
    Jul 2006
    airdrie
    1,549
    how urgent do you need it m8
  26. #146
    Feb 2018
    Hull
    12
    Within the next few weeks ideally
  27. #147
    Jul 2006
    airdrie
    1,549
    i`m waiting on some, i`ll check and let you know
  28. #148
    Feb 2018
    Hull
    12
    Great thank you
  29. #149
    Feb 2018
    Hull
    12
    Any updates mate?
  30. #150
    Jul 2006
    airdrie
    1,549
    hi m8, i`ll nip down tomorrow and see if i can get an idea of time to get some done but if you need one sooner, i`ll sell you my spare
  31. #151
    Feb 2018
    Hull
    12
    That would be great if you could sell your spare as im ready for it to be on and start up then pm me some details as i cant pm yet
  32. #152
    Jul 2006
    airdrie
    1,549
    what details do you need
  33. #153
    Feb 2018
    Hull
    12
    Payment details please
  34. #154
    Jul 2006
    airdrie
    1,549
    hi m8, totally forgot about this. do you still need a pulley
  35. #155
    Mar 2018
    grantham
    16
    do you still make these pulleys ?
  36. #156
    Jul 2006
    airdrie
    1,549
    yes m8
  37. #157
    Mar 2018
    grantham
    16
    how much are they including delivery ? as its pretty much all i need to finish my enfine build
  38. #158
    Jul 2006
    airdrie
    1,549
    they are £65 posted
  39. #159
    Mar 2018
    grantham
    16
    i should have cash transferred into paypal tomorrow could you message me your paypal details please
  40. #160
    Feb 2018
    Hull
    12
    Yeah still need one mate will you pm payment details please
