sierra pinto dizzy wiring ? Help
Im trying to wire up a sierra pinto distributor on a mk2 escort.
Can anyone help me regarding the where the 6 wires go?
I know you only use 4 of them but which 4 and where do they go to?
Thanks Andy
Re: sierra pinto dizzy wiring ? Help
I fitted a sierra dizzy n amp to my old Rs a few yrs ago but I can?t rem now what wires went where.
But if it does help I worked out mine by using an old set of plugs, a drill, a 12v battery plus the dizzy and its amp.
I attached the dizzy to the drill n connected up the ht leads to the plugs, then I just spun the dizzy up and changed the feed around to the amp till I got the plugs to fire. Not the right way I?m sure but it worked lol
I must admit I thought I only used 2 wires from the amp to the car/ignition?
Check this link out, it's from a friends web site. It has all the info you need.
http://myweb.tiscali.co.uk/brayspeed/motorcraft.JPG
