Results 1 to 3 of 3
Thread: Atlas into Mk2
    Spanner Monkey Brayspeed's Avatar
    Jul 2003
    Southampton
    168
    Atlas into Mk2
    Hi All
    picked up an atlas 3.09 ratio with LSD from capri 2.8 special
    Whats the way to go about fitting it ( I would like to keep my 13" wheels ) anyone done it.
    Tony
    BRAYSPEED
    World Champion Decade Plus User 2quick4u's Avatar
    Sep 2001
    The Sunshine State, Australia
    3,717
    Re: Atlas into Mk2
    Your wheels will fit, you will need to make the car body wider by 2 inches each side, or make the axle narrower by 2 inches each side, they will fit fine with tarmac or (most) forest arch kits,
    You need to weld on some new spring saddles in the correct place, Gartrac and Rallye Design both sell these fairly cheaply
    If car is low (or doing jumps) the nose of the axle may hit the diff tunnel
    HTH
    Jul 2003
    Southampton
    168
    Re: Atlas into Mk2
    Hi Mark
    would like to keep axle standard so parts are cheaper if needed, looks like forest arches might be needed.
    Ratio wise how do you think it will be at 3.09 & 13"wheels
    Thanx Tony
