Re: Rollbars
might be off a capri if its wider.
Re: Rollbars
Capri m8 almost deffo
Re: Rollbars
2.8 Capri ones are a slightly different shape, they have a kink where the clamps go on, that one is probably off of a 3.0 S
Maybe a early 2.8 though
Re: Rollbars
Cheers Mark
I'm sure thats another reason why the body might roll so much on my car? esp as it's thinner then a std RS one
Re: Rollbars
Wyn I use a thin roll bar on my tracky, it's just a case of balancing roll bar against spring rates.
And on compression strut cars there is normally no roll bar, they use increased poundage springs.
Re: Rollbars
Wyn,
Ring me tomorrow if you get a minute I will have a chat then and see what we come up with.
Re: Rollbars
Will do
Re: Rollbars
325lbs wyn get the car cornerweighted too might be too much on the front !
Re: Rollbars
you could lower the back and or raise the front, are you on coilovers ?
Re: Rollbars
325lbs wyn
Just rem, guess what I spotted the other day
SPRINGS
Re: Rollbars
No, unfortunately on these still
Id like coilovers but I thought wheel to spring clearance might be a prob, unless I can have them so the spring platforms start from where the original platforms are?
Re: Rollbars
My springs sit higher than the original ones !
