Escort S1 fuel relay wiring
Hiya. I'm having trouble trying to wire my fuel pump relay back up. My mate took the wires off it when we were trying to fix a fuelling problem and didn't realise that the 6 wires were all separate rather than as a multiplug
It's the bigger silver type box. Does anyone know which wires are meant to where?
Any help appreciated as I've got a series 1 sitting on my driveway doing nothing at the moment.
Re: Escort S1 fuel relay wiring
I will have a look to see if I have the wiring diagrame at home. If I do I will post if later for you.
bttt
Anyone? I've got a dead RST sitting on my drive rotting away at the moment.
Ok, according to my diagram....
The terminal on it's own should have a black with yellow trace on it (pin 50, cranking input)
The the other 5 terminals, should look something like the diagram below.
<font color="white">..</font>-
Working from the top and from left to right we have....
black and a black with green trace (pin 15, ignition input) on the top,
red (pin 30, permenant live) on the middle left,
Brown (pin 31, common earth) on the middle row centre,
2 x black with red trace (pin 87, feed to pump, decel fuel cut of valve and solenoid control valve (amal valve)) on the middle row right,
Green with red trace (pin 1, tachometric input from tacho/ negative side of the ignition coil. Might become a solid green wire else where in the loom) on the bottom.
Hope that helps.
Did it help or did I post this for fook all?
Sorry bout the late reply mate
I gave a printout of your wiring diagram to my mate and it worked a treat. Thanks for that, appreciate it.
Good. Glad it's sorted.
