Got some more pics today of my car.
nice car![]()
yep. definately looking good.
much more to do??
i see there ain't no headlining
stripes?? wheels??
No stripes going on m8 roof linning will be done when i get the bits sorted.
It does look better without them.
Nice Mk1
I see your running twin carbs, I am looking to run twin 40's as well but unsure about the clearance on the brake servo & bracket. Did you have to lower the brake servo at all or purchase a lower one?.
King Regards
Ricki.
Ricki
You have to lower the servo, mk2 connecting rods are adjust able to correct the pedal, because if you don't brakes will be applied as you lower the bracket. Add a wedge to the bulkhead maybe as well , this is how my brother done it on his old mk2 sport.
all i had to do was lower it on the inner wing the rod i had was from a mk2 so i had to chop it down and re weld it all seems ok just past MOT today![]()
Sortedall i had to do was lower it on the inner wing the rod i had was from a mk2 so i had to chop it down and re weld it all seems ok just past MOT today![]()
...Even with no number plates????![]()
No i got em today i got a sticker for on the bonnet and a metal pressed one for the back![]()
