Results 1 to 5 of 5
Thread: What is this part number ? 4age alternator belt
    May 2014
    Londinium
    47
    I need to order a new fan belt. Just the one that goes from crank to fan to alternator. No adjuster and multi v ribbed
    The one pictured here
    i43.tinypic.com/30rtfts.jpg
    I keep ordering them and now have a selection of useless fanbelt. .. I need the proper part number please !
    Someone?
    Dec 2011
    Northamptonshire
    733
    Re: What is this part number ? 4age alternator belt
    Best think to do is measure what you need in MM a decent factors can the supply you the correct size most belts read PK then a a number this translates to the size in MM.
    Mechanic Mk1_Deano's Avatar
    Mar 2007
    Maidstone
    30
    581
    9
    The alternator bracket in that picture looks like a mk1 mr2 AW11 and certainly not rwd or 20v given thats a AW11 water inlet housing. Take a look at the epc data in the link below gives you the oem part numbers for the belt in question for that chassis code.
    http://toyota-europe.epc-data.com/mr...e/1605/16361A/
    See if the belts you've ordered previously cross reference with any of these as you may have been ordering belts for the wrong bracket arrangement which could explain the issue.
    HTH.
    May 2014
    Londinium
    47
    Thankyou all for your help
    the actual bracket I have is this one ;
    dorihachigo.zenfolio.com/img/s8/v9/p231528867-4.jpg
    I will be using the measure method next !
    Mar 2007
    Maidstone
    30
    581
    9
    Ah that is the AE86 mount in which case you need these part numbers, although comparing the AW11 and the AE86 belts, it looks like they both used the same belt, i'm sure the last three numbers denote the length too.
    http://toyota-europe.epc-data.com/co...e/1605/16361A/
    I would measure up the length and then see what it ties in length wise with the part numbers above.
    I think I may have a belt that worked on an ae86 mount down my workshop so will have a check when i'm down over the weekend if it helps.
