Ive just fitted a new xflow engine in my mk2 van and got it running.
i have fitted a new Aldon 43D4 103FXYS Distributor with a new lumenition kit, ive set the static timing etc.
When the engine is running the rpm rises and falls a couple of hundred revs, i have rotated the distributor a couple of degrees each way but the fault stays.
Also the mechanical advance seems faulty, when you rev the engine and take your foot off the accelerator pedal the revs dont drop instantly like they should.
There are no noticable air leaks on the inlet side.
I can't get the engine to idle properly is the distributor at fault or the carb ?
Any idea's ?
Andy
