baby atlas... cosworth power
am building a mk1 escort with a yb cosworth in it,
can I run it on standard leafs and aftermarket shocks or dose it need to be 5 linked
some info would be great
sorry if this has been covered before
Re: baby atlas... cosworth power
How much power are you going to be running? 200/240bhp single leafs and tramp bars will be ok but not ideal when going towards the 250bhp mark. any higher i would be tempted with a 5/6 link then.
Going to be running around 300-320bhp in mine. I have a full width Atlas, 225 section tyres on 8x15 rims, decambered springs, poly bushes, anti-tramp bars and panhard rod (3 linked?) - I purposely didn't want a 4/5/6 link setup as I wanted to retain an element of practicality with the interior.
We shall see how it goes - it is road use only though....
With the amount of power I wouldn't want to use lowering blocks - so if you do nothing else, get the springs decambered.
I was hopeing to run about 350ish bhp, but I also wanted to keep the rear seats ect but if needs are a must then I will 5 link it
you dont "need" to 5 link it at all, a lot will depend on how and where you drive it, and whether you find yourself suffering from excessive axle tramp
Ive seen alot of very quick circuit cars runnign tramp bars, leafs and a panhard.
https://www.youtube.com/watch?v=xTQIdKwbtCo
Kevs 4 door at 2.31 is running about 350bhp he is on leafs and a panhard rod
