Results 1 to 3 of 3
Thread: 2.8i into mk3 cortina advice
    Oct 2013
    peterborough
    12
    Hi all,still a ford newbie.
    Just picked up a 2.8i cologne with gearbox.Also got the rad and engine loom. I managed to get a set of 2.3 Cortina engine mounts.
    Just wondering is there anything else I will need to get the engine installed? Cheers.
    Spanner Monkey mihakrapez's Avatar
    Jan 2007
    Ljubljana, Slovenia, Slovenia
    271
    18
    Re: 2.8i into mk3 cortina advice
    Hello, That is about all you need.
    The only think that needs attention is fuel supply as the 2.8i needs 6.5 bars of constant pressure and a return line. So you will need to modify the fuel tank a bit. Not sure about the size of the fuel line, but the best way is to go with a bit thicker pipe.
    Cheers,
    Obstacles are those frightful things you see when you take your eyes off your goal.
    Oct 2013
    peterborough
    12
    cheers,been search the old web,got a bit more info,all advice is much appreciated......
