A full set of Weber 48's needed for the next stage in the life of SKC.
May even go throttle bodies but will look for 48's for now - lol lol
What the hell I post this in Tech Talk for ? - lol lol
maybe the carbs are too technical for you
Erittäin hassu te finnish perse!! I-KIRJAIN odottaa nyt kuluva online kielenkääntäjä tehdas lol lol lol
could you translate that for me?
RS2000CUSTOM
48.s are only an advantage above 180hp.
They are a disadvantage below this level.
RS2000CUSTOM
Go injection m8 try the M3D system with throttle bodies
Or just go the whole way and run 50's! or even better if your feeling flush try a h.t racing slide rail injection set up! theyve done a few pintos now and asp cossies,close to 300bhp out of an aspirated cossie is good but expensive. Also you could go for a 2.2 or 2.3 bottom end,the 2.2 being the cheaper option at around £1800 with forged pistons,should give you over 200bhp then and the 2.3 is a farndon steel crank with cossie rods,more power and loads of low down grunt/torque!
I am going 2wd Cozzy block, crank and rods
93mm (or maybe even 94mm) pistons
Knife edge and lighten crank
Wilcox light flywheel
Full assembly balance
And a head of yet to be decided spec.
Any ideas ?
