Results 1 to 18 of 18
Thread: Small hole top mounts what are my options
    Mechanic mk2-mad-ad's Avatar
    Nov 2008
    stoke
    644
    25
    Been out and bought some nice rubber mounted spherical bearing top mounts from race lovely bit of kit come to fit and hadn't realised mine are the small hole type !!!! So hopefully they will have them back .
    So what are my options for small hole types as I carnt seem to find any of the above for small hole and from what I've read the solid type are a bit harsh for road use so what are my options can they be converted to take a spherical bearing or does anyone know of a manufacture for them with sperical bearings , bearings have gone in my originals and jump on the springs as well as being very stiff as they do
    3,641
    Re: Small hole top mounts what are my options
    Solid alloy type only I'm afraid, you can mount them with rubber between to help dampen a bit, Compbrake to decent ones.
    Nov 2008
    stoke
    644
    25
    Or is it possible to just holesaw the hole bigger and re drill them to accept the bigger top mounts .
    And what size should the hole be for the bigger top mounts
    3,641
    Quote Originally Posted by mk2-mad-ad View Post
    Yes you can do that, off the top of my head large hole top bolts have a pcd of 134mm but double check first.
    Jun 2004
    Bristol
    1,494
    18
    Just make the hole bigger - I've done this a few times
    Line up the bigger mounts centrally and cut the minimum size hole to fit the top mounts
    It's a few years since I've done it, but I think the bigger hole goes through the middle of the original bolts holes, if that makes sense
    Nov 2008
    stoke
    644
    25
    Fab that's that then bigger they will go . Any more info on what hole sizes I'll have to make it would be fab
    3,641
    Nov 2008
    stoke
    644
    25
    Fab so we have
    Small hole 111mm pcd
    Big hole 134mm pcd
    Have been looking at a few old threads on this and as gavinr has said going to go for a 110 mm hole which should end up through the middle ish of the original holes still leavening a bit of metal unless anyone disagrees .
    Or if someone has there car apart to a repair panel handy they wouldn't mind measuring the hole for me thanks
    Nov 2008
    stoke
    644
    25
    Going to go with 108mm which with the spreading washers I'm using should end up perfect on the edge as well as leavening I know minimal more metal there for strength and as there's more choice in hole saws for 108mm than 110mm lol
    Which will leave me a 4 1/4" inch hole as I've read else where is the correct size I think either would do really but with the washers I'm using they won't be over the edge now which will look better
    Dec 2004
    Bucks, England
    Many years ago I successfully fitted roller bearing top mounts to a small hole RS2000 without modifying the inner wings. I had a 10mm thick alloy spacer made to sandwich between the two. Countersunk holes and socket head screws secured the spacer to the top mount and on a slightly different PCD, I fitted captive studs to match the inner wing holes. The spacer was even black anodised for good measure and worked well and looked spot on. The 10mm spacer was enough to allow the slightly tapered tower of the top mount to clear the hole. The thickness of the spacer also made very little difference to the ride height.
    3,641
    Grp4 fabrications and Compbrake do nice small hole mounts
    Nov 2008
    stoke
    644
    25
    Good idea bud , I've now drilled the holes bigger and all is good again lol glad I've changed them it's made a good difference from the tight jumping mounts on there before
    Moderator+ Turbosport Moderator Longman's Avatar
    May 2007
    Leicestershire
    36
    863
    Quote Originally Posted by RWD_Fiesta View Post
    Do you have any pictures of how this ended up mate?
    Sep 2004
    Ireland
    354
    18
    how about trying something different nissan 200sx arftermarket 2 piece top mounts .these have a huge amount of camber adjustment and only need a little bit of fetteling to match small hole pcd about 10 min with a die grinder.they are all over ebay for sale and are well made and fairly cheap.
    May 2016
    Scotland
    27
    Tell me more mate
    Plymouth
    899
    any idea of the inner diameter of the rose joint?
    Jan 2006
    ireland
    183
    36
    Just to revive this old post.
    We have just made a batch of Rubber top mounts to suit the small hole strut tops,
    More info here
    http://grp4fabrications.com/product_...oducts_id=1321
    http://grp4fabrications.com/product_...oducts_id=1322
    Nov 2008
    stoke
    644
    25
    aaaahhhhhhhhhhhhhhhh only did this as no one made them ha ha I noticed you had started making them ow well I'm looking to restore it soon so its going to get a set of full inner wings soon might go back to small hole and get a set keeping it o/e
  19. The Following User Says Thank You to mk2-mad-ad For This Useful Post:
