1700 xflow running temp
when my mex is driving temp gauge is fine but if stood standing for 5 mins gets closer to red is there anything that can be done or is this safe and normal engine seems to get very hot was thinking about getting a mesh fitted over engine instead of buying a bbq can any one advise please thanks
Re: 1700 xflow running temp
My 1600 sits at half unless i find traffic and then sticks up at 3/4 or just below red and then when i turn it off it spits the contents of the rad water out Happened 3 times today so i put in me leccy fan
hi
mine was just below red didnt dare let it go any higher so drove around what do you mean by spiting water out and is it easy to fit a lecy fan i have one does this make things a lot better
cheers jimmy
One of my old mk2 escorts used to do the same. It was my only car at the time and was great fun (not) in the winter when I parked up somewhere to see the shock on the faces of pedestrians when all that steam blasted out form underneath as I walked into the paper shop etc.
I did this for a month or two then one day the head gasket went.
All the water was coming out the excess drain tube thing next to the cap My fan seems to keep it at a constant temp if put on when it gets hot, so today as is boiling again i think ill stick it on when the car gets up to temp Oh and its a piece of piss to fit, just make up mounts, even if its cable ties! and then wire a switched positive (switch in car) and negative to earth (mines on one of the rad bolts)
HTH's
In my x-flow mkII i have an old fiesta fan and that does the job
no probs best to have it on a switch and have a good
temperature gauge though having on all the time will drain
loads of power
so how exactly does the thermostat work would the needle keep going up what happens when thermostat opens sorry for my ignorance
