Hi there,does anyone have a download for the workshop manual of ford escort mk2 pdf?I would really appreciate it.Its impossible to get on the net!Thanks in advance!
I need it too, it is impossible to get on the net nor e-bay or anywhere else.
Would someone be so kind to upload it to rapideshare or some place like that?
This should be a sticky post because everyone who is restoring or repairing an escort must have it and is not easy to find.
Thanks in advance!
hey guys i have the factory work shop manual for the mk2 esky, let me know if you want it, if people want it ill scan it to pdf and upload it
I'd like a copy of that please
Keep her lit
I would greatly appreciate a scanned pdf of the manual. Im in the middle of renovation my mk2 ☺
I have the Haynes versions for both the Basic Escorts and the RS variants that is basically a Ford Workshop manual recycled (had original Ford one and threw it away - DOH) but if some high res. pdf's of the Wiring diagrams could be posted i'd be grateful as the Haynes ones are not good / clear!
I have a pdf of the workshop manual, downloaded it from somewhere earlier in the year. Will look for where it came from.
It's 130 Mb's ...
This is/was the link, don't know if it's still live.
https://mega.nz/#!wlYnlI7K!pQOAe08Qk...0tIuMpgLXwYDQQ
Nice one Leon - good high res. scan so my knackered eyes can read the wiring codes - now just have to figure what goes where!
Thanks Leon, that saves me a few hours
now all i need is the part manual which I can't seem to find anywhere
The workshop manual was made in 1975 when intermittent wipers where not there yet (I guess).
Have a wiring diagram for that somewhere.
Also have the parts manual as pdf but cannot remember where I got that from.
It's even bigger in size, 182 Mb !
Hello Miniliteman, i'm from Greece, my father has a ford escort mk2 1100 with 2 doors, bought second hand directly from Germany, must be model 1977-78.
I try to help him with some parts of the car, car is getting old and needs some maintenance.
Is their any possibility you have a parts manual that shows oem numbers for this car?
Thank you in advanced,
Dimitris
Hello,
yes I have the parts manual in pdf.
If you know of a website where I can share that file without having to register then let me know and I will upload it there.
Regards, Leon.
Thank you Leon, i think Gofile is free without register and no size limit:
https://gofile.io/uploadFiles
Hello,
let me know if this works for you:
https://gofile.io/d/oUsfNt
It works fine, just downloaded. I already found the codes for lights-horn switch and drum brakes (Car wears drums on front and back wheels, but i don't know if front and back drums are the same, i will check it in manual). I'm searching now for the fuel pump, i see all parts of my father's car, all with ford genuine codes!
Anything i say won't be enough, THANK YOU VERY MUCH Leon!!
Dimitris
