Page 1 of 3 1 2 3 LastLast
Results 1 to 40 of 102
Thread: Cossie sump into an old skool ...MODIFIED BY HT...
    Part of the furniture Decade Plus User
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Right, if your fitting a cossie lump into a mk1 or mk2 escort you need to have serious work done to the sump to clear the cross member. The work includes cutting back the belly pan shortening it so it clears the x-member, then having the 'wings' put on the side to compensate for the lost oil by cutting it short.
    You also need to extend the oil pick up pipe so its stuill central in the belly of the sump.
    This one was done by HT Racing in dartford - 01474 872 888 at a cost of £280.
    You need to supply your own sump and pick up pipe, allow up to two weeks for them to do it as they are very busy.
    Seems expensive, and it is but the work is 2nd to none.
    Yodi
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Re: Cossie sump into an old skool ...MODIFIED BY HT...
    Can this go into archives to help others??
    Aldershot
    4,538
    I love how good quality welding looks. My old mountain bike had welds like that. A work of art
    Mechanic Bob2's Avatar
    May 2003
    Surrey
    542
    Yodi just a quick note to say i had to file the crossmember to stop mine rubbing, bit of an arse when its in place so prob worth checking when you first put the engine in!!
    Patrick
    Dec 2003
    London
    10,228
    26
    Right now get that bolted on and il see you up the ace in the car
    Seriously though Ray down there is a top welder and does a top job,just look at some of his fabrication work on the cars they build down there.
    P.S You may have to shave or cut the lip of the back of the crossmember to allow for tilt on the engine
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Kev I'll see you down there soon
    The car was already cossie'd before I bought it and has the same x-member fitted so its already been shaved
    World Champion Decade Plus User 2quick4u's Avatar
    Sep 2001
    The Sunshine State, Australia
    3,717
    My standard cossie sump clears my World Cup X-member with no cutting of the pan.
    Nice work by HT though
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Racer Decade Plus User Mr_Hoarder's Avatar
    Sep 2001
    Essex
    1,563
    You will have fun changing the starter motor when it's all bolted into the car.
    The big wing and the world cup engine mount completely box the starter in.
    This is from experience btw.
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Also did you get my pm??
    Sep 2001
    Essex
    1,563
    I did.
    Pit Crew Decade Plus User Shaun's Avatar
    Feb 2003
    LIVERPOOL
    1,389
    mines still got the standard 2wd sump aswell
    Mar 2003
    Now over the pond North side
    3,540
    So, do you need to get this mod done Or can you get away with a WCXM and a standard sump Dont see as it's worth the 280 if you can get away with it
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Apparently you dont but when I asked you did need it done and now Ive spent £280 you dont
    Dec 2003
    London
    10,228
    26
    Oh yeah i had that problem too,in the end i left the bellhousing bolts out and wedged the gearbox back to get the starter in
    And its definately worth having done to avoid oil surge when going around the track
    TURBOSPORT SPONSOR Decade Plus User
    Turbosport Sponsor
    Jan 2004
    Dorking
    1,445
    If you have a big money engine,is it worth the risk of oil surge?
    Sep 2001
    3,717
    a dry sump setup is best then
    The HT sump is nice and an increase in capacity is useful, but a standard cossie sump is quite good as it is square around the oil pickup pipe which is in the centre, so the oil doesn't surge away as easily as some designs
    Mechanic Slymanrs2's Avatar
    Jun 2004
    South London
    626
    Same here! I put the engine in for a test, first time in the mounts where round the wrong way? and it wouldnt fit, so turned them round and sump clears WCXM and rack, and put a plumb line from the heater bubble to the front and all the plug holes in the head all lined up! wahoo
    may have to trim the lip back on the XM like Kev says
  19. #19
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    My sumps for sale at a loss to myself if anyone now wants it
  20. #20
    Clint's Avatar
    Jul 2001
    933,694
    Here is a pic of a WCXM with the rear cut back about as far as you want to go without loosing any strengh.
    The issue is with the mounts, if you lucky the WCXM mounts will sit the engine about right but some mounts are not jiged very well so engine position is a bit of a lottery if they fit or you can modify them or make your own then you will be able to use the std cossie sump.
    The cossie sump does need baffling for best results though, and big wings are always worth considering if you have the budget.
  21. #21
    Spanner Monkey Scot's Avatar
    Jul 2002
    Scotland
    93
    Why not just have a wing on the exhaust side if you're worried about losing oil capacity and going to have probs with the starter?
  22. #22
    Clint's Avatar
    Jul 2001
    933,694
    Post Copied from another Post with some more info:
    If you trim the x-member up:
    and move the engine back a bit:
    You will find there is plenty of room for a std sump:
    But that dosnt mean you can skimp on spending money at HT's
    If you want to get yours like this then speak to Gary @ RetroMotorsport.
  23. #23
    Sep 2001
    3,717
    Clint,
    the problem isn't usually scrimping that puts people off of the HT sump, it's waiting 6 months to get them to do it
    It's a very nice job but I built my whole car in less time than it took Andy to get his sump done
    BTW,
    For standard cossie sump, if you fit a WCXM from RACE, and nip a wee bit out the back as above pic, it will fit anyway, some of them it fits better if you switch the mounts left to right too, I did that with mine moving the engine across to the nearside slightly, weight distribution was better too
  24. #24
    World Champion Decade Plus User RETRO_AL's Avatar
    skipton
    4,845
    18
    whats the advantage of having one of them sumps you can get more oil in? wots wrong with a standard one or is it some thing to do with surge as well?
  25. #25
    Sep 2001
    3,717
    Yes more capacity and it is also baffled to minimise surge, extra oil capacity is always a good thing.
    I don't believe there is any real problem with standard cossie sump though for most road/ trackday applications, it is a nice square bowl wich helps keep surge down anyway.
    Personally if I was to upgrade the sump on mine I would probably opt for a dry sump system, they aren't really that dear now.
  26. #26
    Clint's Avatar
    Jul 2001
    933,694
    The standard sump is very good, but does have trouble on fast cars, baffling them works very well, the big wings give them nearly double the capacity and allows you to run the oil level a little lower.
    Mark you have to be looking at a £1200 to dry sump a cossie engine properly hows that not dear ?
  27. #27
    Sep 2001
    3,717
    I have contacts
    Besides even at £1200, when you have 10 times that (or 20 times in many cases) invested in the car it's not really that bad,
    when a T4 turbo will cost nearly that, the engine may have cost 4 or 5 times that amount built, I don't think it's a huge price to pay for a proper oil system.
    seems people will happily pay huge sums for many other items but alway baulk at cost of lubrication.
    All IMHO of course
  28. #28
    Clint's Avatar
    Jul 2001
    933,694
    The £1200 was using all my contacts too LOL. Its still dear though
  29. #29
    Pit Crew Decade Plus User nickmk11's Avatar
    Sep 2004
    uk kent
    1,143
    dry sumps .take a look at pace start at £695
    http://www.paceproducts.co.uk/automotive-parts.shtml
  30. #30
    Clint's Avatar
    Jul 2001
    933,694
    Dry sumping really needs thinking about:
    1, what will you do with the under piston oil spray? - run jets if so £300+ for the jets and block machining
    2, should you need a 4th stage on the pump to scavange from the turbo - +£100 on cost of pump
    3, you need a dry sump tank, idealy in the front of the car HT charge £400ish for a custom one, a proper round one will cost £200ish
    Block modification £50+
    Pipes and fittings - £100+
    Sump pan will need to be custom made if you have moved the engine back £250
  31. #31
    Dec 2003
    London
    10,228
    26
    £695 then you have to buy -12 hoses and fittings on top and run them to the boot,thats around £300-350 then the tank for the oil etc.
  32. #32
    Racer Decade Plus User Dom's Avatar
    May 2003
    UK/France
    1,934
    I have to agree with mark that it seems strange that people spend 5-10k on a motor then say dry sumping is to dear I mean if you do dry sump then you dont have to spend £280 on that HT racing wet sump so now dry sumping is down to £900
  33. #33
    Clint's Avatar
    Jul 2001
    933,694
    The point being the Standard sumps are very good in the first place, for a little extra money you can get it modified which will virtually guarentee against a surge failure (HT have not seen a failure down to oil surge with a modded sump).
    You could argue the same point you made about the engine management, why spend 5k on a 400HP engine and not spend £1200 replacing the ECU sensors injectors and loom etc ?
    Its all down to money before you know it you have spent a fortune and for what really, a little piece of mind, which you can get with a few less expensive mods
  34. #34
    May 2003
    Surrey
    542
    Use a gear reduction starter then no probs getting it in and out! U have to turn one of the bolts round to make it easier to fit.
    Obveously no good to people who have a cossie starter already (ie with the engine they bought) but once u pay for the bellhousing mod then it works out roughly the same price!
    Patrick
  35. #35
    Clint's Avatar
    Jul 2001
    933,694
    Move the engine back and thers no problem with the starter....or sump
  36. #36
    May 2003
    Surrey
    542
    True but those like me who are lazey and poor!!!
  37. #37
    Clint's Avatar
    Jul 2001
    933,694
    It would cost about the same as a trick starter and modified sump !
  38. #38
    Turbosport Sponsor
    Jan 2004
    Dorking
    1,445
    I have to agree on standard sumps not being that good,on the track etc.
    Ive heard of a few people blowing up big money pintos,just because thay used a rs2000 sump
    Even after they have been told track day is not the best thing to do.
  39. #39
    Dec 2003
    London
    10,228
    26
    Exactly,look what happened to BMX on track
  40. #40
    Clint's Avatar
    Jul 2001
    933,694
    But wasnt that an oil pump issue ?
    http://www.turbosport.co.uk/showf...part=2&vc=1
