Hi all,
have recently bought a blacktop zetec that came with a Megajolt lite jr as part of the package but I don't know and seller couldn't tell me if is map type or tps type, it has a stub on ecu housing so am guessing its a map one but how can you tell for sure?
it didn't come with any disc, not sure if is programmed for zetec or not, am planning on fitting bike carbs, which are best for standard engine, as going to be a cost effective build not no expense spared type lol.have seen 600 carbs from about £50 but R1 ones appear to be about £200?
i got a inlet manifold kit with the engine, base plate with 4 tubes, are oval end to fit plate and round to fit carbs but are straight about 80mm long ish, the bike manifolds I have seen on e bay look angled?
thanks,
peter.
