Results 1 to 6 of 6
Thread: LSD help
    Jul 2004
    Reading
    1,517
    LSD help
    I have just removed the LSD from my scrap 2.8 Special Capri in preperation of fitting to my Mk 1 Escort. When I spin the wheel the other wheel spins in the same direction, which is good. However, I always though it should spin the other way at first, then lock and spin the same way. Does this diff sound right to you? The car was being used for 1/4 mile runs and the owner assured me it was an LSD, but has he welded it solid? Or is this a sign the LSD plates are worn?
    Mechanic tezscort's Avatar
    Jan 2004
    Stoke on Trent
    47
    567
    Re: LSD help
    sounds good to me unless mine was welded to.
    Mar 2004
    Harlow, Essex
    16,123
    332
    Re: LSD help
    Just take the back cover off and have a look inside, and by saying "removed the lsd" you mean you have taken the back axle off??? because unless you have the tools to put a diff and CWP back in the atlas case dont take it out.
    These are just some of the tools required, and allthough I have the tools to build diffs, I still send them to Salisbury Transmissions, 02084433223.
    Jun 2004
    Bristol
    1,422
    Re: LSD help
    Sounds good to me aswell
    Try holding one wheel still while turning the other, it should be impossible if the LSD is in good condition
    Jul 2004
    Reading
    1,517
    Re: LSD help
    I have just removed the whole diff, I know that removing the actual LSD unit is beyond my humble skills. I will remove the back plate and have a look tonight, fingers crossed.
    Jul 2004
    Reading
    1,517
    Re: LSD help
    All is well, it is an LSD!
