Re: red top whats involved
Hello and welcome m8
As for putting the xe in an escort i`ll give you a rough guide
chassis mount it or wcxm and special eng mounts whatever you do i think the bulkhead will need some modding
sump from a 1.8 manta or modify the org or buy an after market 1
change the bellhousing and clutch plate u can use a type 9 5 speed box
twin 45 are best for the fueling or throttle bodys etc if u got the dough
electrical side is a dizzy conv that bolts to the side of the engine (see my siggy pic) now like hens teeth SBD did make them but stopped about a year ago this limits you to the power as its a bit primative
or SBD do a eleccy ign pack etc not cheap but its fully mapable and with 45`s should give around 170 brake on a standard engine
if u use the manta sump the engine has to be mounted on a 7 degree slant and all the bits bellhousing,inlet man etc need to be the 7 degree ones
Hth im doing 1 on a mk2 hopefully
CheeRS James
Piece of cake then basically!!
Welcome to the site tho mate!
cheers 4 that m8 has helped alot doesnt sound that bad really bit of tinkering
do u no if u can buy like a kit with the mounts and bell housing and sump????
if so any ideas where from ?
