De-Cambered Springs
I`ve heard the term used used a lot.
I dont really know what it involves.
I want to get the back of my mk2 lowered about 6inch (from standard ride height) I have 2 inch blocks on at the moment,
but it needs to go another 4...
So... Is this possible?
Where do i buy these springs from, or where do i go to get
mine "Sorted"
So one gunna tell me to get it 4 linked and fit coil overs...
Yes, i would love to, but i dont really wa nt to spend that sort
of money...
OR
Is that my only option?
Cheers.
Re: De-Cambered Springs
to get them decambered Mark
check you local yellow pages for leaf spring manufacturers and they will be able to do it, my local firm 20 miles away does them for £10 the pair all they do is put the spring in a big hydraulic press and inch by inch take the <font color="red">take the bend out</font> , this is on single leafs, multis take alot more work and time
Brian
these lot are in yorkshire ? http://www.lesjoforsab.com/default.asp
Unit B6 Warhurst Road, Lowfields Business Park, Lowfield Way, Elland HX5 9DF
West Yorkshire, Great Britain, Tel +44 1422 37 07 70 Fax +44 1422 37 72 33
Tinsley Bridge Limited
Tel: 0114 221 1111
PO Box 89, Shepcote Lane, Sheffield, South Yorkshire
Suspension spring manufacturers. Parabolic Leaf Springs Stabiliser Bars Torsion Bars Anti Roll Bars. [0]
or
Meadowhead Spring Works
Whitworth Street
Milnrow
Rochdale
Lancashire
OL16 4HG
United Kingdom
Tel: (01706) 715800
Fax: (01706) 715801
http://www.lancashire-spring.co.uk
more on this list
http://www.manchesterhasit.co.uk/business/6424/
where are you oop norf then ?
Gartrac do them, its best to get a pair of new ones done so they end up exactly the same, you only really want 1" blocks too.
So will they still be as stiff?
I bet you can 8 link the car for the price Gartrac charge for
their springs...
Isn`t it better to have NO lowering blocks?
Gartrac Springs arnt that bad, and they are top quality, I think they charge £20 a spring to decamber.
Prices on thier site probably www.gartrac.com
I'm still thinking of the chassis rail to axle interference fit... 6" drop? that would fit the axle against the chassis rails, so dont worry about de-cambering the springs, just weld the axle to the chassis rails...
Being serious, can you measure what gap you have between the top of the axle and the chassis rail, as a standard escort only has around 6" between them and if you allready have a 2" drop then you should have 4" inches of clearence. Going another 2" is the max drop but could cause some scary moment as the suspension goes solid
Try it, you can always swop the blocks over for smaller ones.
A Hardtail Escort LOL
Ford Escort meets American Choppers, brought to you by RetroMotorsports.... More Amps
Well... i got the springs done. £45 for the pair.
Guess the 4 link is on the back burner for the time being.........
